Rust Removal in the Rain Gutter Area, 53 f100...
It's called seam sealer and made by 3M or Sem as well as others. It come in a caulking tube (best for gutters and exterior seams) or brushable can. It should be available at any professional body and paint supplier. There are several types, be sure what you get is for exterior use and is paintable. You want to put down about an 1/8" thick layer and be sure it fills completely side to side to make a watertight seal.
OOPS! I just looked at the container, it's made by Rustoleum and called "rust reformer" It comes in a 16 oz white plastic rectangular container with a red cap with an applicator pad attached to the side. I also have it in a smaller round black plastic bottle with a spout top and even in a rattle can. I get it at Home Depot in the paint dept. with the cleaners and chemicals. It's a bit pricy, but a little goes a long ways.
Be sure to wear rubber gloves when you use it or it will turn your hands black which won't wash off. Only use it on rusty surfaces it won't react with clean metal, but it stops rust permanently.
Lukes66
42
06-24-2019 01:56 PM
bart f-350
07-28-2017 03:42 AM
peterfak
07-22-2017 05:23 PM
peterfak
03-26-2017 03:06 PM
command37
09-12-2016 02:41 PM
