For those looking for Leveling Kits!!
Old 10-12-2010, 06:29 PM
jrciii56's Avatar
jrciii56
jrciii56 is offline
Bilstein
Looks like a much better option than the spacers.
Old 10-12-2010, 10:44 PM
Jimmy Dean's Avatar
Jimmy Dean
Jimmy Dean is offline
I would rather one that lowers the back a few inches instead....that should be easily accomplished though anyways.
Old 10-13-2010, 05:54 AM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
I'll be geting at set of bilsteins soon also best price I found was $102
Old 10-13-2010, 06:58 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
Subscribing.
Just the amount of ride height adjustment I'm looking for. Bilstein makes a great product.
Old 10-13-2010, 07:50 AM
Mudd460's Avatar
Mudd460
Mudd460 is offline
$102 Each?
Old 10-13-2010, 09:40 AM
juneau76's Avatar
juneau76
juneau76 is offline
Originally Posted by Mudd460
$102 Each?
Shockwarehouse has them for $102.63/each. By the way, thank you for your service to our country.
Old 10-13-2010, 06:12 PM
jrciii56's Avatar
jrciii56
jrciii56 is offline
363.14. That is a good price for a set of 4.
Old 10-13-2010, 07:09 PM
silver05fx4
i was going to do rancho quick lift but bilsteins are haft the price
only down side to bilsteins is that you must take the spring off
Old 10-13-2010, 07:17 PM
jrciii56's Avatar
jrciii56
jrciii56 is offline
I think I might be worth it for half the price. If I end up keeping my truck, I am going to install a set on mine.
Old 10-13-2010, 07:47 PM
juneau76's Avatar
juneau76
juneau76 is offline
I noticed that Shox.com has them for $339 for the set of 4. Just an FYI.
Old 10-13-2010, 08:19 PM
Mudd460's Avatar
Mudd460
Mudd460 is offline
Your Welcome!
Old 10-15-2010, 09:19 PM
jrciii56's Avatar
jrciii56
jrciii56 is offline
Thanks Nice!! Cheaper there than other places I have found.
Old 10-15-2010, 10:22 PM
Nicky817Nick's Avatar
Nicky817Nick
Nicky817Nick is offline
Just wondering... Is it suggested that you have a wheel alignment after install????
Thanx...
Old 10-16-2010, 09:48 AM
jstnromero's Avatar
jstnromero
jstnromero is offline
yes...anytime you adjust/alter the suspension in any way...it is recommended to get an alignment.
Old 10-17-2010, 07:18 PM
rockstate45's Avatar
rockstate45
rockstate45 is offline
Few things about the Bilsteins. The Tundra guys are running them over there on their trucks so I'll give you the two cents from what I've gathered over there.
1. They're good for the amount of lift they state. Seems like most people max out at 2.5" lift on the DC and, probably a hair less on the Crewmax (Bilstein says 2.25")
2. They ride better than stock Tundras. Stiffer yet more controlled than the TRD shocks (they're ever stiffer than the non-turd tundras).
3. I went with the Old Man Emu kit for my truck since I have a 112 lb brush guard up front. I wanted it to control the weight better with new shocks AND coils. The Bilsteins will take 180 lbs and sag only .25" according to one of their reps. Knowing that, I might have done it... but I really like the way my OME turned out, so it was good for me.
4. Rancho Quiklifts I've heard don't get stated lift and are a pain to deal with. IMO, money is better spent on Bilsteins even if they were more expensive.
5. They should make lowering shocks like that for the trucks. I believe they do for the Tundra. All they do is relocate the spring perch.
Also, recently they've been shipping out with the wrong spring perch on the 5100s for the Tundras. They've correct the problem by shipping new ones to existing orders. Good customer service, but make sure what you have is right before you spend a good bit of money putting it on. Dig up the correct mm for it and measure it.
Anddd, here's a review from one of the guys that put it on his truck. One of the least flattering comments, but it's contrasting what most people say.
Now I am glad I didnt read your post before I woke up this morning Hollack, or I might not have made the decision I did.
I had the 5100's backed off to the middle position and then aligned (massive + camber, small toe-in). The wheels are now verticle instead of bowed out at the top, +.5" rake, and the ride is way smoother.
Changing the perch position on the 5100's was a trade-off though.
My evaluation:
Top setting - extremely stiff and harsh over individual bumps (like a pot hole), decent over perpendicular objects (like railroad tracks). It felt earily similar to a 2500HD truck. No body sway while turning at any speed. You can feel when you run over a pebble (I have 20's, with 18's I'm sure that condition would be diminished considerably).
Middle setting - good over any type of bumps, very similar to stock, but without as much body roll.
I am very happy with the change with 20's. If I had 18's and added a 1" rear block, I may not have found the top position so irritating. 275/60/20's look great on my truck and they dont rub anywhere, at any angle/compression.
-rockstate
Quick Reply: For those looking for Leveling Kits!!
