6.7L Oil Change Info - Clarification
Come on, this sounds like we should all toast to PAUL. Put some meat on those bones, and I too will raise my glass. What did Jack Webb say: "Just the facts"...
How was the the oil pan issue resolved from the 6.4's? Was a large enough sump designed into the 6.7? From my limited knowledge, seems we need a 5 gallon sump, because above, you still say fuel oil slobber gets into oil pan. There are so many good words FORD coins, such as bed plate, I cannot keep up with the jargon.
I am still gun shy of the 6.7, but looking! OOPS, on edit. I had 3 gallon before, when I meant 5 gallon, so we don't have to short stick our oil checks. SORRY...
Please explain? What was right about it. More than 20% of the bedplates warped. The cab comes off. Then the engine comes out. AND Navistar had that right??????
on
The pan is a poly-composite material that is far superior to the traditional pans. It's lighter and insulates against NVH as well. I did a video review of the drain plug during my first oil change. Here's a link to the thread in the tech folder if you care to watch it.
https://www.ford-trucks.com/forums/9...nge-video.html
Fair question... I will answer some of the specifics for block design in a separate thread.
-Paul
-Paul
Curious, I did my first OC today, at 6,000 miles, and the oil definitely smells weird and it is black as coal baby. This is my first diesel so maybe the smell is to be expected given the chance for fuel in the oil.
Has anyone else seen that the oil is THAT black? Again, maybe it's a diesel thing. I ran the V10 on Motorcraft synthetic blend, and when I changed it it was still somewhat transparent, somewhat but pretty dark.
Also, I saw 13 quarts to fill after changing filter. I put 13 in and it's not even on the cable, even after I let it idle for 10 minutes and then sit for about 5 more and then checked.
on
#28
I've got a similar one, lower profile and wider opening, color is yellow. Mine came from Wally World or Auto Zone but I've had it for 10 years or more. Did mine the same way, hold it up to the truck pull the plug and then set it down. Get you a 5 gal jug from floor cleaner or a paint bucket and use that to carry the oil back to the parts store with.
#29
