28 v lights?
28 v lights?
ok i know this isn't really the section for this but i figured alot of you guys know this kind of stuff and seem to be very helpfull. I can easily get my hands on some landing/taxi lights from an aircraft, and Ive heard of people using them on their rigs. I do alot of off-roading with my truck so i wont be blining people down the highway with these, but I often get called at 0200 by friends of mine that are stuck out in the woods and I always end up having too pull them out and the stock headlights arn't cutting it anymore. How would i go about using these lights on my truck (ive confirmed with a e&e troop friend of mine that they are 28 vdc)
Received 3,107 Likes
on
You can also get 12v variants of the lights. Something from a Cessna 150, Cessna 172, Cessna 152, Cessna 182, Piper Cherokee... many to choose from.
http://www.aircraftspruce.com/catalo...ndinglites.php
Unless you're going to run the 400/450/600 watt bulbs, I'd stick with a 12v system and keep it simple.
just for the record im a crew chief... not a zipper-suit. i hit things with hammers (really freaks the army guys out when they walk out to a slick and im beating on something with a smile on my face) and i dont do stupid stuff like write up "i.f.f. in-op in o.f.f. position" thats a true story by the way
on
For the 28V lights, you're going to need a step up transformer setup or a dual battery setup.
The issue with landing lights is they tend to get hot and burn out at low speeds/stopped. I'm going on 2 years(250W 13V) on the set I have on my Dodge, but, I attribute that more to luck than anything else.
My favorite is the "Friction locks causing throttle lever to stick"
I always attributed most of the landing light failures on GA aircraft to vibration. Cowl mounted lights were burned out with amazing regularity. On the other hand our 172's landing light is in the left hand wing and behind a lexan/plexi leading edge section and doesn't receive any direct air cooling at all and hasn't had to be replaced for as long as the plane has been in the family (about 15 years now).
