Power Steering Pump Flush
This thread is mainly for the new guy that wants to do this but thinks they need two people to do this job. I did this job by myself and yes it would of been nicer to have a second person but it's doable by yourself, doing it by yourself you just get more of a work-out.
All you need to do is turn (Tires off the ground) the steering wheel a little (three little turns) while pumping the brake and watch the tubing you have running to a gallon jug. It pretty much went like this for me, turn the wheel/pump the brake get out refill the pump, then repeat. I could have stopped at 2 1/2 Qts but I went ahead and ran 3 1/2 Qts through just to make sure I had all the old stuff out
I followed this write-up
Ford Super Duty Power Steering Flush | Superdutypsd.com
I also used Mobile 1 synthetic ATF, and after doing the fluid change my pump has quieted down but it was pretty warm here today, I'll see if it really worked once the temp drops.
.....Tom
.....Tom
Justins311
1999 to 2016 Super Duty
12-24-2018 08:27 AM
creator
16
10-11-2016 10:28 AM
rcarter301
09-04-2016 01:52 AM
nstueve
80
02-05-2016 12:33 AM
