Performance Distributors new 5.0L F-150 Firepower Ignition Kit
Engineered specifically for the F-150 5.0 ignition system, Performance Distributors new F-150 Firepower Ignition Kit will provide you with measurable performance gains.
The Dyna-Module has more electronic dwell time dialed into it to provide you with more coil saturation time. The extra dwell time allows your coil to produce a more intense spark and crisper acceleration. Mounts in the original equipment location.
The Screamin Demon Coil allows you to open up your plug gaps to .060″, burning your fuel more completely. Working in conjunction with the Dyna-Mod, the Screamin Demon Coil produces a longer duration spark. No drop off in
power as you accelerate. The brass terminal coil tower is more conductive than the
stock aluminum terminal, while also resisting corrosion. Your spark plugs stay
cleaner longer. A heavy duty brass terminal cap and rotor are included in either Blue
or Red.
Live Wire Plug Wires are constructed with a space age, heat resistant
sleeving, able to withstand up to 1400 degrees! Approximately ½â€ in diameter,
the Live Wires look as good as they perform. Spiral wound core prevents
electronic interference-no radio noise or computer interference. Each wire is
numbered for the correct cylinder.
Components are available separately or in kit form. Order the entire kit at
once, and receive a 10% Discount! For more information, contact Performance
Distributors, 2699 Barris Dr., Memphis, TN 38132, (901)396-5782.
