Sponsored by: Halo Lifts
2.7 ecoboost stalls, dies after towing
Old 11-09-2017, 10:49 AM
BNR's Avatar
BNR
BNR is offline
After several hours of towing a 5000# travel trailer @ 65-70 mph, the engine will stall and die after coming to a stop. It will restart, but will only run for a second or two before it dies again. Check engine light does not come on. It will start and die like this repeatedly. To get going again, it will stay running if I hold throttle open a little and take off quick. Took to dealer to get it checked twice. No codes are found, dealer can't replicate problem. Says they can't do anything to fix.
This is very disconcerting , as we travel to some remote places, don't want to get stranded.
I've found two other reports of this problem in these forums, but no solution was reported. With millions of these on the road, others must be having similar issues.
Any new information on this issue?
Old 11-09-2017, 01:48 PM
storage_man's Avatar
storage_man
storage_man is offline
Don't know where your towing, but could it possibly be overheating ? But not to the point of boiling over, since these trucks have overheating protection and will shut the engine off !
The following users liked this post:
Old 11-09-2017, 07:30 PM
onug's Avatar
onug
onug is offline
Your post reminded me of two similar situations that I’ve seen on this forum the past few years. I’m not sure how those turned out; maybe ping the owners of those trucks and see what they found out?
And post back here please...
Old 11-10-2017, 08:07 PM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
The last one I saw that was similar was some issue with the radiator. IDR, whether they flushed it or replaced it, but they were able to run a test on the radiator to determine that its function was sub-standard.
Speculation was that "something" had been embedded in the radiator, and was restricting flow.
Old 11-12-2017, 06:25 PM
beagletim's Avatar
beagletim
beagletim is offline
Before looking at your radiator, be sure to check your coolant level.
Old 11-23-2017, 04:55 PM
vnleclaire's Avatar
vnleclaire
vnleclaire is offline
Sounds like an over heating problem . Do you have a trailer tow package with your truck? Possible something wrong with your radiator or your coolant lever is low.
Old 11-24-2017, 05:43 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,665 Likes on 1,358 Posts
OP appears to be "One and done". I certainly would like to hear "the rest of the story..."
Old 11-25-2017, 11:13 AM
GlueGuy's Avatar
GlueGuy
GlueGuy is offline
Sigh. Maybe it was something simple (trying to give the benefit of the doubt).
Old 11-29-2017, 06:33 AM
dnewton3's Avatar
dnewton3
dnewton3 is offline
There is a similar thread in this section.
It is my suggestion you consider that it may be "vapor lock" of the fuel.
Towing requires a lot of energy to be expended; we all know that. And the 2.7L is a very power-dense engine to begin with. So consider what happens ...
- towing generate high heat loads
- slowing or stopping the vehicle greatly reduces airflow which would otherwise be dissipating heat energy from the engine bay
- low fuel conditions (not a full tank) reduces the available mass to "cool" the fuel, prior to being sent up for it's return trip to the engine bay (the lower the fuel level, the less fuel mass to absorb heat before heading back to the engine
I don't have one of these trucks, so I cannot help replicate or offer any specific advice. But I'd suggest tracing the fuel lines and seeing if they travel close/near any heat sources like headers, cats, turbos, heads, etc; anywhere heat will be concentrated.
Two generic suggestions:
1) add insulation anywhere you can to shed heat away from the fuel lines
2) consider putting a fuel cooler in the supply side of the fuel line; many generic ones to choose from in the aftermarket (a good tube/fin cooler with perhaps 75 sqr-in or more would likely do fine
I cannot assure you that vapor lock is the cause; but it just makes sense given the conditions both threads speak of.
Old 02-11-2018, 07:52 AM
psc6's Avatar
psc6
psc6 is offline
new engine
I had the exact issue with my 2016 ecoboost and the dealer was told by Ford Canada to replace the whole engine. I was not given a reason on what was wrong with the original engine. I have towed my 3900 lb trailer once with the replacement engine and have had no repeat issues. The RPMs appear to be lower and the truck will run in 5th or 6th gear as opposed to not leaving 4th gear. It is frustrating that I could not receive any explanation for what was causing the issues.
Old 02-13-2018, 11:59 AM
vnleclaire's Avatar
vnleclaire
Stalling while towing
Although I have not tried it yet, you can log what you engine is doing as its running using Forscan and OBD link MX. You will have to download the Forscan app for android and purchase the OBD link MX.
What's new
Old 02-20-2018, 08:30 PM
Y all the issues's Avatar
Y all the issues
Y all the issues is offline
2.7 ecoboost
I I just had the same issue over this last weekend family day passing a vehicle when all of a sudden it just died shifted down by the time I stopped it wasnt running anymore engine light flashing restarted it and it was only idling at half speed got it towed to nearest Ford and today I got a voiceail saying bank 1 cylinders are all dead and worst of all I just got heads replaced 2000 km ago because the TSB issue the were having with them
Old 04-04-2018, 02:54 PM
Appleman1's Avatar
Appleman1
Appleman1 is offline
Revisiting the thread
Was there ever a solution for this? I have a 18 2.7 and it did the same thing towing our trailer to Florida and back. Happened about 8 different times. Going to my dealer Friday. Just wondering if anyone found a solution before I take it in.
Old 04-04-2018, 03:27 PM
Y all the issues
2.7 issues
my issue was solved sprocket for timing chain broke at the crankshaft not letting time chain turn which shut down one of the heads valve stayed open Pistons came and hammered on to the valves fixed was basically new motor after 28 days I finally got my truck back with no compensation for me and being stranded in Alberta so I'm finally back home in Saskatchewan
Old 05-31-2018, 08:51 PM
vapor40's Avatar
vapor40
vapor40 is offline
Same thing is happening to mine as well. Usually after towing for 200 plus miles at highway speeds
Quick Reply: 2.7 ecoboost stalls, dies after towing
