• Recalls
  • Technical Service Bulletins (TSBs)
FORD Technical Service Bulletins
Check for technical service bulletins (TSBs) on your vehicle by make, model, and year.
Frequently Asked Questions - FAQ
What is a Technical Service Bulletin?
A Technical Service Bulletin (TSB) is a document that identifies an unanticipated vehicle or part issue and provides a solution. There can be more than one TSB for the same issue if different technicians or engineers have figured out different solutions. A TSB may be provided to dealerships, sent to auto repair shops, or sent out to vehicle owners, depending on the range and scope of the problem.
What is the difference between a Recall and a Technical Service Bulletin?
While a recall concerns a safety issue which must be fixed, a Technical Service Bulletin just identifies a common issue and documents a solution. The difference is that manufacturers are not required to make the repair at no cost for a problem documented in a TSB. However, the circulation of the bulletin amongst dealerships and manufacturers can help diagnose the issue and lead to faster and more efficient fixes.
Do I have to pay or will the manufacturer pay for the TSB related repairs?
Dealers and manufacturers are not required to pay for a repair indicated in a TSB since the issue is not identified as posing a safety concern. There may be repairs that a manufacturer agrees to pay for, however, particularly if the repair has the potential to cause a class-action lawsuit for the manufacturer, and these notifications evolve from a TSB into a "service campaign" or "service warranty".
How do I find out if a TSB has been issued for my vehicle or part of my vehicle?
The Technical Service Bulletin tool on this site can be used to determine if there are outstanding TSBs on your vehicle. Simply select by vehicle year, make, and model.
FORD Recent Technical Service Bulletins
  • FORD F-150
    350000 EQUIPMENT
    RECORD_ID: 4589164
    Bulletin Number: TSB 24-2126
    Replacement Service Bulletin Number: N/A
    NHTSA Item Number: 10254176
    Date Posted: 04-29-2024
    Component Name: 350000 EQUIPMENT
    Make: FORD
    Model: F-150
    Year: 2023
    Date Added: 05-03-2024
    Summary: This article supersedes TSB 24-2093 to address the revised software and include affected 3.5L FHEV vehicles. Some 2021-2023 F-150 vehicles equipped with a gasoline, hybrid or flex fuel engine (non-Lightning) except 2023 F-150 with 3.3L may
  • FORD F-150
    350000 EQUIPMENT
    RECORD_ID: 4589163
    Make: FORD
    Model: F-150
    Year: 2022
  • FORD F-150
    350000 EQUIPMENT
    RECORD_ID: 4589162
    Make: FORD
    Model: F-150
    Year: 2021
  • FORD F-150
    110000 ELECTRICAL SYSTEM
    RECORD_ID: 4589161
    Bulletin Number: TSB 24-2124
    NHTSA Item Number: 10254175
    Date Posted: 04-26-2024
    Component Name: 110000 ELECTRICAL SYSTEM
    Make: FORD
    Model: F-150
    Year: 2023
    Summary: This article supersedes TSB 23-2425 to address revised software and update the Parts List. Some 2022-2023 F-150 hybrid vehicles equipped with a 3.5L PowerBoost engine may exhibit an illuminated MIL with diagnostic trouble codes (DTCs) P0420
  • FORD F-150
    100000 POWER TRAIN
    RECORD_ID: 4589160
    Component Name: 100000 POWER TRAIN
    Make: FORD
    Model: F-150
    Year: 2023
