Velocity Restorations Bronco Restomod is Coyote-Powered Beast
Velocity Restorations has spared no expense in their latest build. From Dana axles to their own serpentine drive, no detail has been overlooked.
By Andrew Nabors - November 9, 2021
NEXT
BACK
Velocity Restorations Unleashes Coyote Power
1 / 9
Clean is an understatement
2 / 9
Creature Comforts
3 / 9
Incredible Ground Clearance
4 / 9
Everything You Could Ask For
5 / 9
Perfect Color Combination
6 / 9
Get Shift Faced
7 / 9
Fun in the sun
8 / 9
Just As Clean Underneath
9 / 9
This stunning build by Velocity Restorations spares no expense. Tasteful upgrades like audio and leather pale in comparison to the late-model Coyote 5-liter. Also onboard is an automatic coupled to an Atlas transfer case. Everything you could ask for!
Photos: Velocity Restorations
This build shows incredible attention to detail with meticulous touches throughout the cabin. The interior is awash in tan leather, showcasing Velocity's prowess at making bespoke seats, center console, and dash. Their own brand of gauges, seats, and floor trim can't easily be replicated.
>>Join the conversation about this restomod Bronco by VR right here in the forum.
Creature Comforts
In an open-top 4x4, audio comes from all directions. Velocity chose to build door panels that capture the essence of the late 60's styling along with a solid enclosure for Kicker 6.5" speakers. A powered 10" box has been integrated with the passenger seat, so Rock On! Check out the Vintage Air kick panel vents, keep your toes cool!
We heard you like approach/departure angles! Nothing beats the look of 17" Mickey Thompson wheels. They are wrapped in 33' BFG A/T and stopped by the largest Wilwoods offered.
Like its modular ancestors, the Coyote is a physically tall and wide V8 engine. Hydroboost brakes not only look great, but they also have better stopping power than any vacuum booster. Velocity made their own headers and serpentine drive because this is the first comprehensive Coyote-powered Bronco.
From the stitching of the seats to the paint on the dash, nothing was overlooked. The interior steel was obviously panted in the same PPG Anvil Grey. Then the dash, doors, and interior panels were also block-sanded. A column-shifter automatic sends power to a divorced transfer case while you listen to Alpine audio. We wouldn't have it any other way.
Get Shift Faced
While the 6-speed auto is shifted on the Ididit column, the transfer case sticks are billet and wrapped in the same premium leather.
Fun in the sun
Thankfully, your passengers won't be burned by the UV-blocking leather, and the floor panels have been coated with a composite bed-liner for long life.
Take a moment to notice how straight the body panels are. Once the body was down to the bare metal, the frame, floors, fenders, and every surface was ground smooth. Every surface was treated to countless hours of block sanding, even the bumpers are better than new. All this can be yours for $224,900 A big thanks to Velocity Restorations for sharing this one with us.
NEXT
BACK
