Velocity Restorations and Roadster Shop Team up to Build Wicked Bronco
What do you get when you combine street rod style and attention to detail with a first-gen Bronco? Well, you get this amazing machine.
By Brett Foote - July 23, 2019
NEXT
BACK
Making an Exception
1 / 10
Two Shops, One Idea
2 / 10
Coming Together
3 / 10
Put the Power Down
4 / 10
Hog Wild
5 / 10
Nicely Integrated
6 / 10
Green With Envy
7 / 10
Custom Touches
8 / 10
Work of Art
9 / 10
Fourth Quarter
10 / 10
Making an Exception
The Goodguys Rod & Custom Association typically focuses on older cars, mostly those from the street rod era. But even they couldn't help but shine a light on this gorgeous 1976 Ford Bronco dreamed up and built by two notable hot rod shops.
Photos: Mike Harrington for Goodguys
Two Shops, One Idea
Velocity Restorations and the Roadster Shop are both very well known entities in the world of custom cars. Velocity is no stranger to Broncos either, building some of the baddest restomods on the planet.
>>Join the conversation about this restomod 1976 Bronco right here in the Ford Trucks Forum!
Coming Together
The idea came about when the two companies were talking during the 2017 Goodguys Nashville Nationals. At the time, Roadster Shop was wanting to develop a complete chassis for the early Bronco. Meanwhile, Velocity had a customer's build that just rolled into the shop. It was a match made in heaven.
Put the Power Down
Thus, Velocity immediately got to work tearing this Bronco down to its last bolt. And they certainly didn't go soft on the powertrain, opting for a Whipple supercharged 5.0-liter Coyote developing 525 horsepower at the wheels.
Hog Wild
They went hog wild on the interior as well, covering most everything in soft custom leather. The updated dash now holds modern digital gauges, new switches, and a Vintage A/C setup.
Nicely Integrated
There's also a barely noticeable roll cage, Kicker stereo system, Steer Clear offset steering coupler, and Ididit column present, all of which do a great job integrating modern components without sacrificing the original look.
Green With Envy
To match the beautiful tan interior, the team at Velocity went with a custom PPG green on the outside, which covers every exterior panel. There's also a subtle gold stripe that adds a nice touch of contrast.
Custom Touches
The exterior also features a host of signature Velocity updates, including flush-mounted glass, a shaved tailgate, hidden door hinges, custom billet headlight, and taillight assemblies, custom fabricated bumpers, and a hidden winch.
Work of Art
The custom Roadster Shop chassis is a work of art as well. It features an independent front setup with custom A-arms, 12 and 13-inches of travel front and rear, dual-rate springs, and Fox 2.5-inch twin-tube bypass shocks.
Fourth Quarter
This amazing Bronco was pieced together in just 90 days, which makes it all the more impressive. But what else would you expect when two of the best in the business get together to build one killer ride?
For help with the service of your truck check out the how-to section of Ford-Trucks.com.
NEXT
BACK
