Top 7 Super Duty Mods
Just when you think you can't make your Super Duty any better, here are some mods that will take it to the next level.
1. Running Board Light
Running board lights do play a beneficial role when you are getting into your truck at night, but they play a better role in making it look good. Running board lights can be purchased in any color, so make your Ford Super Duty truck unique with the color of your choice.
2. Bed Liner
A bad liner of some sort is the best investment you can do for your Super Duty truck. Whether you choose a cover, a spray-on, or a roll-on, just be sure to get one so you can protect the bed of your truck from any scratches and rust. The professionals claim the spray-on is the best you can get for your truck.
3. LED Headlights
Replacing the stock headlight with LED bulbs can change the looks of your Ford Super Duty truck. As if it doesn't have enough presence, the LED lights will make it stand out on whatever road it turns on; not to mention how much it will enhance your visibility at night. You simply can't go wrong with LED headlights.
4. Tool Box
Installing a tool box in the back of your Ford Super Duty makes for a much easier storage. If you've ever owned a truck, you know how frustrating it is to collect your tools, groceries, or fishing gear from all around the truck bed. A tool box is the easiest, most organized way to haul your small things around; plus it makes the truck look that much tougher.
5. LED Light Bar
The LED light bar installs on the roof of your Ford truck, and it makes night driving tremendously better. These bars come in a variety of sizes and power, but they will all make your path much shiner; not to mention how monstrous it will make your Super Duty look.
6. Grille Guard
Installing a grille guard on the front of your Ford Super Duty is like making it officially a Viking. Grille guards play a much bigger role than make your truck look absolutely savage; they protect the expensive front of your truck. However, their looks alone make it worth every single penny.
7. Lift
What is a truck if it is not lifted? Lifting your Ford Super Duty truck can make for an extremely fun drive, as well as makes it tackle rougher terrains better. Whether you replace a few parts of your suspension system, or you install a lift kit to raise your car, the outcome will be most desired, as your Super Duty will look nothing short of scary.
Check out our how-to section for information on maintenance, modifications, and repairs.
