This 1939 Ford Pickup Went From the Field to the Drag Strip
This well-used 1939 Ford pickup used to do work on a farm, but now it's a real hot rod.
By Brett Foote - September 26, 2023
NEXT
BACK
Second Chance
1 / 7
Vintage Looks, Modern Mechanicals
2 / 7
Decisions, Decisions
3 / 7
Big Ford Mill
4 / 7
DIY
5 / 7
Evening Things Out
6 / 7
Second Try
7 / 7
Second Chance
When one thinks of a farm truck, it conjures up images of a ratty old, beat-up, well-used machine that has earned its keep hauling hay, pulling things, and, well, just serving as a trusty workhorse until its usable life is gone. After that, at least in the old days, farmers used to simply park them somewhere and forget about them, leaving these rusty, patina'd pickups for years, at least until people started swooping in and saving them. However, this 1939 Ford farm truck - owned by Robert Lowe and recently featured at MotorTrend - was treated to an extra special second chance at life.
Photos: MotorTrend
From the outside, this vintage Blue Oval hauler certainly looks like it's been sitting outside for many years, because, well, it has. However, while Lowe kept all of that hard-earned patina and surface rust, he went to town underneath the skin by adding a series of serious mechanicals that make it seriously quick down the quarter-mile.
Photos: MotorTrend
Using nothing more than his own tools and a two-car garage, Lowe proceeded to tear into his newest acquisition, with a big decision to make right off the bat - which sort of monster motor would he shoehorn in the engine bay? While many would go the Bow Tie route, that isn't the case here at all, thankfully.
Photos: MotorTrend
Big Ford Mill
Instead, Lowe went with a 427 cubic-inch, 351 Windsor-based mill, which is packing serious goodies like two 80mm VS Racing turbochargers and a Holley Dominator EFI system, in turn sending copious amounts of power to the wheels via a Powerglide transmission and a 9-inch Ford rear end built by Strange Engineering.
Photos: MotorTrend
DIY
What's even more notable about this 1939 Ford pickup is the fact that Lowe did a ton of custom fabrication work himself - in his garage - including building the chassis, creating a roll cage, and even putting together the four-link rear suspension setup.
Photos: MotorTrend
Evening Things Out
He also went with a rear-mounted radiator in this case, given how tiny the underhood areas are on these vintage pickups, and he further aided weight distribution by putting both batteries back there, too. Those things might cut down on cargo space, but this old Ford is pretty much done hauling things, anyway.
Photos: MotorTrend
Second Try
Now that his wicked build is completed, Lowe routinely participates in no-prep racing events, and most recently took his vintage pickup out for Hot Rod's Drag Week. There, it competed in the Ultimate Iron class, working to find redemption after last year's event ended early due to an axle-bearing failure. Regardless of what happens this time around, it's safe to say that Lowe at least has one of the coolest pickups in attendance.
Photos: MotorTrend
>>Join the conversation about this '39 Ford pickup dragster right here in the forum.
NEXT
BACK
