The Case for 1998-2011 Ford Rangers
Daily Slideshow: With domestic trucks only getting larger and more costly what's a smaller midsize truck lover to do? They're not getting any younger, but Ford hit upon a winning formula with 1998-2011 Rangers.
By Brian Dally - August 20, 2018
NEXT
BACK
Workhorse
1 / 7
Inflation
2 / 7
K.I.S.S.
3 / 7
Pistons and Gears
4 / 7
2001 Update
5 / 7
All the Trimmings
6 / 7
Dependability
7 / 7
Workhorse
By the time the turn of the millennium was approaching, the days of planned obsolescence were long gone. Manufacturers needed a vehicle line to catch on and stay caught on for as long as possible. The longer a model could go without changes, the easier it was for an automaker to recoup their investments in design, development, and tooling. Though the 2019 Ranger is a very different beast, U.S.-market Rangers from their inception through the demise of the third-gen evolved gently, and with that last generation-spanning 14 years, FoMoCo certainly got their money out of the little truck that could. A platform that lives multiple years is good for consumers as well—older models don't experience a sharp drop in resale value when a newer version comes out and parts costs can be kept low. The Ranger's compact size and economical base four-banger engine remained attractive to the truck buying public during its run, and as a used model they still make sense to many today.
Inflation
Smaller than they appear in pictures, which is a nice trick by the way, it seems strange to think of the Ranger as anything but a tiny pickup in today's world. The previous generation of Ford's small truck is indeed modest next to the 2019 "midsize" Ranger, but the Ranger line started out as a true midsize, above foreign and domestic mini trucks, yet below traditional full-size models like the F-150. By the time the third generation Ranger debuted in 1998, Ford gave the Ranger a minor facelift and moved to address the lack of space in standard-cab rangers by stretching regular cabs by three inches.
>>Join the conversation about 1998-2011 Ford Rangers right here in Ford-trucks.com.
K.I.S.S.
Buyers in search of endless combinations of cabs, doors, beds, and what have you, have always had the F-150 to step up to, but down in Rangerland things were kept a little more simple. Available as a regular cab with six- or seven-foot beds or as a SuperCab (which got you sideways folding rear seats) with a six-foot bed only, wheelbases extended from 111.5 inches on the short side to 125.9 on the longest.
Pistons and Gears
To go with your choice of three body styles, Ranger initially offered three engine choices. In ascending order, the options were a standard 2.5-liter SOHC inline four-cylinder putting out 117 hp, a 3.0-liter pushrod V6 making 145 hp, and a 4.0-liter pushrod V6 cranking out 158hp. You're not winning drag races with any of these, though the 4.0-liter offered a usable 223 lb-ft of torque for buyers who wanted to tow something larger than a trailer full of brush. A five-speed manual transmission was available with all three engines, a four-speed auto could be coupled with the four and the smaller six, and a five-speed auto was an option for the larger six alone. Additionally, if you wanted your ranger with 4WD it had to have a V6 under the hood.
2001 Update
With the 2001 model year came updated engine options. The SOHC four was replaced with a DOHC 2.3-liter inline-four rated at 135 horsepower, the 145 hp 3.0-liter pushrod V6 was held over, and a new 207 hp OHC 4.0-liter V6 superseded the old pushrod 4.0-liter V6. A new five-speed automatic was now an option, and the pushrod six was gone for 2009.
All the Trimmings
Although powertrain changes were modest, Rangers were a little more generous when it came to trim levels and packages. A few notable choices were the FX4, a heavy-duty four-wheeler with large diameter wheels; the XL Trailhead, a "4x4 look" RWD-only model; and the Splash, which sported body-color fender flares.
Dependability
Despite their strengths, Rangers were not immune to reliability issues. Four-wheel-drive system problems showed up on 1999, 2001, and 2003 Rangers; 2002 and 2004/2005 models experienced ball-joint headaches; and engine sensor issues were common in the 1999-2002 model years. Despite these problems, Rangers proved to be more reliable than Chevy's competitor, the S-10, although somewhat less reliable than Toyota Tacomas from those same years—but then again, what isn't? Until and unless Ford actually makes a pint-sized pick-up again, lovers of extra small Ford trucks will have to make do with used Rangers. Thankfully, there are still plenty of those in service.
NEXT
BACK
