Step Back in Time With this 1932 Model B Pickup
A lot of work has gone into making this truck run like new. We wonder if they had any clue way back in 1932 that this pickup would still be trucking along?
By Robert Bacon - March 24, 2020
NEXT
BACK
A Piece of History
1 / 7
Drivetrain
2 / 7
Fresh Metal
3 / 7
Brakes
4 / 7
Engine Specs
5 / 7
Suspension
6 / 7
Interior
7 / 7
A Piece of History
The 1932 Model B Pickup pictured above has been owned by its builder for the past 28 years. But now, it's going up for auction. The build was finished a few years ago and has fewer than 700 miles on it since completion.
Photos courtesy of Mecum.
Drivetrain
Under this car's hood sits a pristine balanced 276 ci 8BA industrial Flathead V8 motor. All of this engine's power runs through a Ford C4 automatic transmission with shift kit Gennie floor shifter, before it's sent to this truck's Currie 9-inch rear end.
>>Join the conversation about this 1932 Model B pickup right here in the Ford Trucks Forum!
Fresh Metal
This model has a Henry Ford steel cab, running boards, and hood. It also comes fitted with Wescott fenders.
Brakes
Bringing this pickup to a halt are early Mustang disc brakes up front, while drum brakes take care of things at the rear.
Engine Specs
This Model B's engine is, arguably, the truck's best feature. It's been fitted with forged pistons, Elderblock Heads, an Isky 3/4 race cam, a Mercury crank, and a 4-barrel carburetor with electric choke. It also has a Mallory dual point ignition as well as a Melling fuel pump.
Suspension
Keeping things under control at the front is chromed TCI suspension with a 4-inch drop. At the rear, you'll find TCI Four Link suspension with coilover shocks.
Interior
The inside of this truck is just as pristine as its exterior. It features vinyl upholstery and Stewart Warner gauges.
For help with service of your truck, check out the how to section of Ford-Trucks.com
NEXT
BACK
