It Took Five Years to Create This 1971 Custom Bronco
Although it took five years to create this beauty, you don't need to worry when taking it off-road. This is one tough truck!
By Robert Bacon - February 11, 2020
NEXT
BACK
Custom Build
1 / 8
A Real Off-Roader
2 / 8
Power
3 / 8
Modern Touches
4 / 8
Exterior
5 / 8
Interior
6 / 8
It's Tough
7 / 8
Like New
8 / 8
Custom Build
The '71 Ford Bronco pictured above looks like it rolled off the production line yesterday (albeit with some major upgrades). This is all down to a five-year-long custom build journey that the owner has been on.
Photos courtesy of Mecum.
A Real Off-Roader
Even some of the trickiest off-road trails won't phase this restomoded Bronco. It features a Krawlers Edge 4-link suspension system with Bilstein Shocks. It also has custom radius arms, and custom shock mounts. Ground clearance shouldn't be a problem either thanks to its 4 1/2-inch lift.
>>Join the conversation about this classic 1971 Bronco right here in the Ford Trucks Forum!
Power
Propelling this beauty is a 5.0-liter Ford Coyote V8 engine which was installed by BC Broncos. All of this unit's 435 horsepower runs through a 4R70W automatic transmission with overdrive.
Modern Touches
This Bronco is 49 years old but full of modern features. It's been fitted with a computerized onboard real-time engine diagnostics system with a driver's display. And, for entertainment, there's a dual touch Apple CarPlay head unit.
Exterior
The custom sky blue paint job with offset matte trim is outstanding and sure to turn heads from a mile away.
Interior
The aesthetics only get better as you climb into this beast. Inside you'll find custom Italian leather seats and panels, as well as custom carpet up front and a wooden floor in the bed.
It's Tough
Some people might be hesitant to bring such a jaw-dropping vehicle on a rocky trail, but it really was built to go off-road. Underneath its custom exterior, you'll find reinforced steering linkage and full plate protection over the drivetrain.
Like New
Since its build, this Bronco has only racked up 40 test miles. So, if you're the winning bidder, you'll basically be getting a brand new truck.
For help with service of your truck, check out the how to section of Ford-Trucks.com
NEXT
BACK
