Daily Slideshow: How Safe is Your Sunroof?
As other aspects of auto construction get safer, sunroofs lag behind.
By Brian Dally - March 26, 2018
NEXT
BACK
Growing Concern
1 / 5
In Court
2 / 5
Regulations
3 / 5
Laminate
4 / 5
Airbags
5 / 5
Growing Concern
Does your vehicle have a sunroof? If so you're part of the increasing number of people opting for a sunroof-equipped car or truck each year, WardsAuto reports that last year 40 percent (seven million total) of the cars and light trucks sold in the U.S. featured a sunroof, up from 33 percent in 2011. When opting for a sunroof did you consider the safety trade-off that might go along with more light and a better view? National Highway Traffic Safety Administration data shows that each year from 1997 to 2008, approximately 300 people were killed, and 14,000 people were injured, from incidents in which they were thrown through their sunroofs—whether the roof was open or not. A more detailed study from 2016 reports that between 2002 and 2012, in accidents where the sunroof was closed, approximately 230 people were killed and 500 were injured when they were ejected through sunroofs. With many manufacturers offering nearly roof-sized glass in their vehicles, it might come as a shock that there simply aren't any safety requirements specifically addressing sunroof ejection.
>>Join the conversation about how safe your sunroof is right here in the forum.
In Court
The NY Times recently recounted the story of Liza Hankins, who in 2005 as an 18-year-old had the sunroof closed on her 2000 Ford Expedition when she was involved in a crash on the way to work. Her truck's glass sunroof popped out and she was thrown from the vehicle, resulting in her being paralyzed. Her family sued Ford, claiming that the vehicle was unsafe and that the automaker used tempered glass rather than laminated glass to save costs. Ford argued that there were no government regulations that require either an open or closed sunroof to prevent a person's ejection from a vehicle in the event of a crash. A jury found for the automaker. Ford didn't contest the fact that tempered glass is less expensive, but they felt that the greater risk of potential brain and neck injuries from occupants' heads hitting laminated glass outweighed the threat posed by ejection of belted occupants through the less-sturdy tempered glass. (In the suit Ford argued that Hankins was unbelted, Hankins denies that she was.)
Regulations
In the 13 years since Hankins' accident, the N.H.T.S.A. has looked at regulating sunroof safety. In 2011, when the agency established rules designed to prevent side-window ejections, they also considered regulations covering sunroofs but decided against implementing any. The agency pointed out that while 62 percent of ejection deaths involved side windows, out of the 10,000 ejection deaths annually between 1997 to 2008, only 3 percent involved sunroofs. Safety watchdogs weren't happy with the non-action and felt that the decision ignored a mandate from Congress in 2005 to address vehicle ejection dangers. That may change though, as the N.H.T.S.A. has stated that it's, "actively looking into this issue and continues to analyze information related to the structural integrity of sunroofs."
Laminate
And those may not just be idle words, as last year N.H.T.S.A. officials revealed that they had come up with a performance test to measure the mounting and structural soundness of sunroof glass. Of course both logic and research indicate that wearing a seatbelt is the best way to avoid any ejection from a vehicle, but forensic engineering specialist and automotive collision legal expert Stephen Batzer has stated that a "partial ejection" is still a possibility in some crashes. Batzer says that any regulation covering sunroofs will likely require laminated glass. "From a safety perspective, the most important aspect of the roof being laminated is to ensure that the occupant stays in the compartment in case of a rollover,” said spokesperson Russell Datz from Volvo, a company that favors its use in sunroof construction. Elizabeth Weigandt, a spokesperson from Ford, says that automaker also uses laminated glass in its sunroofs, "depending on engineering requirements."
Airbags
In order to comply with the 2011 N.H.T.S.A. regulations governing side-window ejections, manufacturers have turned to side-curtain airbags. With new data on sunroofs and new dangers from larger expanses of glass, it seems likely a similar solution will be applied to keep occupants of sunroof-equipped vehicles safe. South Korea's Hyundai Mobis, supplier to automakers including Hyundai and Kia, claims they have developed the first sunroof airbag. Their airbag activates in a crash whether the sunroof is open or not, and the company says to look for it appearing on new vehicles in the next year or two. The former head of the N.H.T.S.A., Joan Claybrook, cites recent requirements for backup cameras as evidence that two hundred to three hundred fatalities a year is enough to initiate increased regulation. Whether changes will be initiated by manufacturers or mandate, safety-conscious sunroof shoppers should look for their favorite brand to feature roof airbags sooner rather than later.
NEXT
BACK
