Daily Slideshow: 5 Essential Tools for Ford Truck DIYers
A majority of Ford truck owners not only take pride in their vehicle but the work that they put into it. While most projects are carefully planned out, especially those done to improve the look or performance of the truck, other times the work is necessary in order to keep the vehicle running. If you own a Ford truck, do yourself a favor and check to make sure you have these essential tools on you at all times.
By Jeffrey Bausch - January 18, 2018
NEXT
BACK
1. Wrench and socket set
1 / 5
2. Flashlight
2 / 5
3. Floor jack
3 / 5
4. Duct tape
4 / 5
5. Tow strap
5 / 5
For less than $200, you can get yourself a comprehensive suitcase full of sockets to handle just about any and all projects. A ton of companies sell these sets, including Craftsman, Husky, Kobalt and more. Things to consider when buying one – is the suitcase small enough to keep in your truck at all times, do you have a wide enough range in sizes, and what’s the warranty on it. When you find a set you’re comfortable with, make sure to throw it in your truck; don’t leave it in your garage. These sets have a tendency to prove useful when you least expect them to.
>>Join the conversation about the tools someone will need to fix whatever ails their pickup right here in Ford-trucks.com.
2. Flashlight
This is a tool that more often than not is overlooked, but absolutely essential to keep in your truck. A flashlight is good to have because it provides visibility into the hard-to-see parts of your truck; it’s also useful should you have any issues with your truck at night time and need to pull over.
3. Floor jack
Whether you find yourself stuck on the side of a road, or have an afternoon free to do some work under your truck, a car jack is an essential tool for Ford truck drivers. When purchasing one, make sure to take the following into consideration – is it easy enough to store in your truck, what is its capacity, and how high is its lift? Find the right jack for your Ford truck and store it in the vehicle.
4. Duct tape
Duct tape is one of those tools that is essential to keep on you because it can fix just about anything. Broken headlight? Use some duct tape to secure it so that you can get home safely. Sprung a leak in a hose? Use the duct tape to patch it up till you can get it to the garage.
5. Tow strap
If you keep a tow strap on you, you can put your truck to good use by helping another car get out of a ditch. You can also use a tow strap to help a driver out whose car won’t start and needs to be towed to a mechanic. Of course, these scenarios can be vice versa – should you ever find yourself in one of these predicaments with your Ford truck, a tow strap can prove to be tremendously helpful in getting you out.
NEXT
BACK
