10 Aftermarket Products at SEMA for Ford Trucks
If you want to complement your Ford truck, try modifying it with one of these products at SEMA.
1. A.R.E. Truck Cap
This product will make your truck the best of both worlds. You can have the space of a pickup truck, without worrying about leaving things in the bed. The truck cap is high enough to fit anything you want, and you can lock it and leave whatever in it without worrying about it getting stolen.
Check out this product and more HERE.
2. Airaid Cold Air Intake
Give your Ford truck some cold air, and watch it perform. Airaid had a booth at SEMA and they promise you horsepower, a roaring engine, and better fuel consumption with their cold air intakes.
3. Andersen Hitches
This is no ordinary hitch, this is a No-Sway hitch. Andersen Hitches introduced their latest weight-distribution hitch at SEMA this year. This product features motion dampening system, so you never have to worry about your trailer swaying around, not to mention the lifetime warranty that gives you an absolute peace of mind.
4. Baja Designs LED Light
Light up your path with these powerful LED lights. The Squadron LED light, made by Baja Designs Inc, produces 3,600 lumens in a small 3x3 inch light. This is the perfect, small addition to your Ford truck that is guaranteed to light up your world.
5. Cap-Pack Truck Products
Whether you use your Ford truck for work, or you're just not a fan of a mess, this product will make your life easier. The Cap-Pack storage system goes into the bed of your truck and allows you to organize all of your items. This is a great way to encourage yourself to use the large bed of your Ford truck.
6. Cargo Ease Ramp
Cargo Ease has made loading and unloading your Ford truck extremely easy. This ramp doesn't take up much space, and it can easily and quickly be folded in and out, which allows you to either walk up or slide anything up the ramp to load.
7. Carr Foldable Steps
You no longer have to blow out your knees trying to climb up your Ford truck. Carr introduced their foldable steps at SEMA this year, and they're easy to install. This step installs to your rear hitch, and it can easy be folded up, maintaining the good looks of your Ford truck.
8. Catalyst Industries Tie-Down Clamps
These tie-downs can install to the front or the rear of your Ford truck. If you use your truck for work, or if you're known to haul irregular things, this is a great way to secure your load. Install them to the front of your truck and tie your load from the roof to the front, or install them to the rear and secure your load from there.
9. Endurance Truck Accessories Side Bars
Give your Ford truck an aggressive look with these sidebars. Whether you have a lift on your truck, or you just want to make yours and your passengers' lives easier, these side bars, made by Endurance Truck Accessories, will make going in and out of your truck a breeze.
10. Fox Racing Shox Performance Shocks
Take your Ford truck to the next level with these performance shocks. Fox Racing Shox are bolt-on performance shocks that dissipate heat three times faster than regular steel shocks. Install these for better handling, more durable suspension, or to make your Ford truck a much better ride.
If you have a Ford truck project you need help with, check out the how-to section at Ford-Trucks.com, as well as the helpful forum archives.
