5.8 cylinderhead upgrade revisited
I have also learned that the earlier heads do not have enough meat on them to have the thermactor air passage drilled through them as you may eventually hit the water jacket. Which is too bad because I payed some bucks to have them professionally ported, polished, coated and flowbenched.
I just got off the phone with Summitracing and will have a set of Edelbrock
performer aluminum heads with the 1.90/1.60 valves, 60cc comb chambers and 7/16's rocker studs expedited to my mom's by Friday. These will get a nice set of comp pro mag 1.6 chromoly roller rockers to smooth things out a bit along with the top of the line trickflow hardened pushrods
So...after the edelbrocks get put on, I will have the Bronco dialed in and dynoed and A/F ratios printed out for the Diablo chip match up. (details to follow)
Intake has been portmatched and coated with heat disp coating bottom has been coated with thermal barrier coating.
I will also order a bassani Y pipe and have it thermal barrier coated by Microcoat in Santa Rosa, CA.(details to follow)
anybody take a guess at what the dyno will say? Any other recommendations?
206/215 duration @ .50" with 112 LSA
.470/.470 lift
stock injectors, new fuel psi reg, unported edelbrock performer heads and portmatched stock intake.
Ignition is a stock duraspark dizzy and the MSD6A control box with ford racing 9mm wires and NGK irridium plugs.
Diablo chip to be made to match the added air the heads, intake and cam provide. (the changes are so mild that it negates the need for larger injectors)
I am hoping for 250hp and at least 360ft lbs of torque.
.470/.470 lift
later
cam is as follows:
.470/.470 lift
building my 95 Bronco to be an Impala SS Killer.
My guess would be 275-325 Hp. let me know of the outcome, I'm
Your in a bronco Bucky, just run over the impala its a chevy anyways LOL And I would love to hear what the dyno has to say I need some more ponies in my stable too! Good luck.
