Modular V10 (6.8l)
1999 v-10 Fuel Pressure checking procedure
Old Nov 14, 2007 | 08:06 PM
denk's Avatar
denk
How do I check the fuel pressure on a 1999 v-10? I have a Fuel injection gage but have read different threads on where and how to check pressure and test for 'bleed-down' of pressure and am a bit confused.
Old Nov 15, 2007 | 09:18 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What would I do?
First, hook the gauge to the fuel rail.
At idle, with engine running, you should see 28-30PSI.
With engine off, key on, you should see about 38-40PSI.
With engine running, and vacuum disconnected from the fuel regulator (and plugged), you should see 38-40PSI.
Under load, foot to the floor, vacuum to fuel regulator connected, I'm not so sure, but it should be above 35.
Wait for others to comment, I might be crazy
Old Nov 18, 2007 | 10:30 PM
biz4two's Avatar
biz4two
Arrow
From what I remember...Krewat is right on the money!
biz
Old May 18, 2026 | 02:52 PM
jziegler's Avatar
jziegler
Did you find a way to test the pump? My fuel pressure kit only has a 5/16 T fitting, so I can't test the pump pressure without the engine in line. The pressure regulator was replaced 4 years ago, and I am having a misfire code on bank 1. So, before I go down the road of replacing coils, I want to make sure the pump can deliver 45 psi.
Old May 18, 2026 | 04:02 PM
ashleyroachclip's Avatar
ashleyroachclip
The Schrader valve will be a fine place to check pump efficiency. With engine off ,key on the prime the rail , and gauge , cycle the key a few times looking for maximum preasure, then turn key off and watch to see how long it takes the pressure to bleed off .
Old May 18, 2026 | 04:20 PM
jziegler's Avatar
jziegler
With the in-line gauge at the tank, the 3/8 line gets KoEo 32 psi, idle 34-36 & full throttle (parked) is 42 psi. 5/16 line is only 32psi.
In case anyone else is looking for the dead-end plugs - Dorman #800-330 & 800-337.
Old Yesterday | 10:42 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
I don't think I've seen anyone check at the tank. All of us check at the Schraeder valve on the fuel rail.
jjjet
Motorhomes (Class A,B,C & Super C)
Mar 7, 2025 02:18 AM
LazyDazeDude
Jan 25, 2025 01:57 AM
Brian C 12
1997 - 2003 F150
Nov 5, 2020 08:22 PM
Aerostar1
Aerostar
17
Feb 19, 2007 11:03 PM
rangerchief
1983 - 2012 Ranger & B-Series
Feb 27, 2005 09:59 PM
