Anybody tried this? Looks like it could help simplify mounting the clamp. I guess you feed it up from below to install. Or give the bellows a good twist.
Hmm. Interesting. Haven't seen those before. I like the idea if they fit well. 0 gaskets at all with that setup. The description says they get rid of the donut gasket and use a crush gasket instead. They may want to update that. lol
I got so sick of fighting with that clamp on the baby's butt.
Now I just remove the downpipe, attached the turbo to the collector on the bench, attach the pass side up pipe to the collector on the bench, drop the up pipe down the side at the same time I mount the turbo with the 2 bolts.....then feed the driver side up pipe from the bottom.
Takes me less than 15 minutes to install the whole thing, and that includes reinstalling the down pipe.
