Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1969 F600 - Set me straight
Old Jun 12, 2026 | 10:48 AM
linksvu's Avatar
linksvu
6th Gear
Hey all, just got a 1969 F600 dump truck that I’ll be working on, so set me straight on where to get info (besides this forum) to work on it. I’ll clearly be searching through this forum a lot but I’m sure there are other sources out there. So, where have you found to be the best sources of info on these (again, beyond here)? Is change for a service manual?
Also, any immediate tips or suggestions? It’s a great runner; shifts well (when I don’t grind 'em); brakes are soft; parking brake is weak; has an oil and rear axle leak.
Specs of mine: 330, 5-speed, 2-speed rear
Old Jun 12, 2026 | 11:10 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
For bumpside cab parts discussion, you've started in the right place already. However, given that your new to you 1969 is an F-600, FTE's Large Truck subforum will be of interest to you, and your F-600 will be of interest to the regulars who hang their medium duty truck hats over there.
Old Jun 12, 2026 | 01:18 PM
linksvu's Avatar
linksvu
6th Gear
Good suggestion, I'll do that!
Any pointers on these trucks?
Old Jun 12, 2026 | 01:44 PM
linksvu's Avatar
linksvu
6th Gear
Also, here's my door tag, if someone is able to give details on the build.
Old Jun 12, 2026 | 02:13 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The first pointer I might suggest is to take a more legible photo of your door tag. Consider tracing the ridges of all the stamped characters with a black sharpie, or take the photo in less ambient light, or if you can control the exposure setting of your camera, reduce the exposure so that the bright metal numbers don't wash out.
Then, Super Mod @85e150 or Community Team Member @asavage can help you decode all of the details on your F-600's original build. Asavage has a similar truck, in a similar color. You'll be in good hands and fit right in with the regulars of FTE's Large Truck subforum.
Old Jun 12, 2026 | 04:26 PM
85e150's Avatar
85e150
F61 = F600 gas, 4x2
D = 330 2V HD FT gas V8
K = Kansas City Assembly Plant
F11326 = 1969 model year, May 1969 production. (Please confirm this number is correct)
156 = 156 inch wheelbase
No color code? If so, color might have been part of the special order. This appears to be a standard color though.....
F615 = F600 gas, 4x2, 24,000 lbs GVWR
4B81
4B = Black Leather Grain HD Vinyl
81 = (with the numeric/alpha "4B") Standard Cab, cab and chassis vehicle
O = New Process model 541 five speed direct transmission
E3?
E3 = Eaton model 16244 two speed rear axle, 17,500 lbs capacity, 6.50 / 9.04 ratios
? = Front axle code is not legible
24000 = 24,000 lbs GVWR
164 3800 = 164 Certified Net HP @ 3800 RPM
54241?
54 = Omaha District Sales Office
241? = Special Order Number.
5&2, 24,000 GVWR. Nice specs. 361 or 391 would make it more better....
Old Jun 12, 2026 | 04:50 PM
asavage's Avatar
asavage
FTE Community Team
OP has an identical thread in Large Trucks:
https://www.ford-trucks.com/forums/1...direction.html
I've decoded the warranty plate (as possible) over there [too late, I see now].
Old Jun 12, 2026 | 05:52 PM
85e150's Avatar
85e150
I didn't realize it was in the other forum when I did the decode.
I'll merge these later if it makes sense. Two decodes can be better than one.
Mt Pleasant Farmer
Large Truck
Aug 30, 2020 10:32 PM
49F-4
15
Jan 14, 2019 09:39 PM
mattandchels
Mar 13, 2017 11:33 PM
jdubsweb
Feb 29, 2016 07:28 PM
48fordf3
May 18, 2005 10:47 PM
