1979 Ford F100 with OEM 9” and 273 gearing. 5.0L Gen 3 Coyote Swap with 10R80 transmission about ~ two weeks from being done. Existing tires 205/75R15 being replaced with 235/75R15. Shop owner informed me that I should be open to changing gear ratio to something like 323 or 350. Seeking suggestions with others experiences doing the Coyote and 10R80 swap. Truck will be used for some around town driving and ~ 700 mile trips fishing a couple times a years. Thanks,
I generally like to be turning a little less than 2000RPM at 70 in the numerically lowest gear ratio. A 3.73 would put you at 2100-ish in 9th (0.69) and 1900-ish in 10th (0.64). Your problem is the steep 1st gear ratio (4.7). With the size and width tire you're running it is going to be a smoke show every time you launch. Although the Coyote is a bit of a peaky, high revving engine it should easily have enough torque to achieve good gradeability in 9th or 10th though without experiencing shift busyness (depending of course on how the pattern was calibrated) so maybe a 3.5 is a good compromise?
This is all about compromises. You're going to have to make one somewhere. Do you want to keep the engine speeds lower on the highway and accept a lot of downshifts to maintain a grade or accelerate, or do you want to avoid that but then deal with the fact that you are going to be buying a lot of tires if you are a heavy footed driver? It might help if you go with a wheel that is a bit wider. 235s being subjected to that kind of power with no weight over the rear axle is a little silly.
Ha Viper Pilot,
Like your thinking and I'm with you, with the sweet spot RPM between ~ 1950 and 2150 at 70 MPH. Definitely no heavy foot here, Commercial Driver License background where as we anticipate lights avoiding coming to full stop, saves on fuel and allot of shifting. The 235/75R15 tires are practically new that I'll use until they surpass the DOT date and then change. Want to stay with my Ford OEM 10 hole aluminum wheels, considering my OEM wheel width limitation what tire size is suggested with 3.50 gearing?
I would leave the gear ratio where it is until you drive it around some
You are liable not to notice the low gears with the engine and trans upgrade
I would not go higher than 3.50 or so ratio even if you do decide to change the ratio
Ha Viper Pilot,
Well, if you go up in tire size you effectively lower the rear axle ratio. In that case, you could run a numerically higher axle ratio and still keep the engine speeds down. For example, if you went up to a 31" tire and used a 3.73 your engine speed in 10th at 70MPH would be 1800. I would definitely go wider. 275 at least. You can probably find aftermarket reproductions of the wheels you have that are made in different widths.
ok, using the above calculator,
I get 1,991 rpms running 70-mph with 4:10 gearing in .64 OD (10th ?) and 31-inch rubber. _ eh ?
and
at 100-mph above at 1:1 direct, you'd be turning 4,444-rpms easy peasy for a Coyote.
