Fuel Gauge stopped working
Old Yesterday | 04:09 PM
66Classic96's Avatar
66Classic96
I removed instrument cluster from my 1966 F100 Custom Cab in order to replace bezel and lens. Fuel gauge worked before removing but now does not work after reinstalling cluster. I grounded the orange wire going to the sending unit/ float assembly and gauge did not move. I removed instrument cluster voltage regulator, gave it a little shake and could hear something rattle inside it. I ordered a new regulator from Dennis Carpenter and installed. Gauge still not working. I have previously replaced sending unit/float assembly. I grounded the terminal for the orange wire on the back of the gauge, gauge did not move. What kind of reading should I be getting on the orange wire at the fuel tank sending unit/float assembly? Are there any other tests to try before ordering a new gauge? Thanks.
Edit: With test light I have power on 1 side of regulator, gets hot to the touch. At orange wire to the sending unit test light will not light up. Ohms tested sending unit. With out touching sending unit, meter reads OL. When touching sending unit meter reads 0.0. The Dennis Carpenter regulator has female terminal on the left, male on the right. Original regulator was opposite, female on right. male on left. Would that make a difference?
Old Yesterday | 04:31 PM
TA455HO's Avatar
TA455HO
Lead Gopher
If you have an adjustable DC power supply, you could remove the gauge and bench test it from 0 to 5 volts DC input. Don't apply more than 5 volts maximum.
Old Yesterday | 05:26 PM
66Classic96
Do not have one of those. Thanks.
Old Today | 01:29 PM
Crop Duster's Avatar
Crop Duster
Here is an old thread to read it might help you figure out the problem. Fuel gauge issue - Ford Truck Enthusiasts Forums
Old Today | 05:10 PM
spurredon's Avatar
spurredon
Just the way they put it together. The female should read 12 volts with the key on where it plugs onto the male coming into the ICVR, the female connector should then read 5 volts where it leaves and goes to the gauge.
ehewson
Jun 9, 2025 05:07 PM
ztstewart
May 10, 2022 10:05 PM
Jay Wells
Large Truck
Sep 13, 2020 11:20 AM
Highboy74
80
Mar 19, 2013 10:16 AM
trickysF100
Aug 14, 2011 12:00 PM
