PSA: drivetrain vibration
Old Yesterday | 04:58 PM
StrongHandRich's Avatar
StrongHandRich
6th Gear
I’ve had a drivetrain vibration since the truck was new. 11.6 axle with 4.30 gears. Almost inaudible, but sounds like wumm wumm wumm at speeds between 68 and 75.
Peak was at 73. Most people in the truck couldn’t pick up on it, and the service manager at the local dealer said it needed the factory wheels and tires put back on (it was on the stock wheels and tires and this was 100% different from a tire vibration). I sweet talked the service writer into getting a driveshaft for it and there was no change.
anyways, ford specifies the u joint angles at the tcase and pinion should be equal, or not more than 1* different. (For a 1 piece driveshaft)
Mine measured 4.7 on the tcase, and 3.2 on the pinion.
measured a bunch of other super duties in the fleet where i work and found them to be .3-.4* different front to rear, with the largest variation being .7*.
I put in a set of 1* shims I ordered from ford and vibration is gone. 4.7* at transfer case and 4.4* on the pinion is where it ended up.
here is the ford part number: 8C3Z5A313C
Old Yesterday | 09:52 PM
esolcz's Avatar
esolcz
Good for future reference. Thanks! Ed
Old Yesterday | 11:58 PM
brandon4's Avatar
brandon4
Thank you for putting in the work on this. Good to know.
Sanchadog
Nov 13, 2019 08:19 PM
wanta79
13
Apr 13, 2010 01:48 PM
RFD_Truckie
Dec 11, 2009 08:55 AM
dave91gt
Apr 4, 2009 08:37 PM
Sporto
1966 - 1977 Early Broncos
Jul 11, 2005 04:28 PM
