1994 F250 351w Crank No Start, No Fuel Pressure at Rail
Old May 23, 2026 | 08:33 PM
Ford POWERSTROKE 7.3l's Avatar
7th Gear
The truck cranks, but doesn't want to start, and there's no fuel pressure in the rail. I know the midship tank fuel pump works, and the fuel filter isn't clogged. but it's just been kicking my butt
Old May 23, 2026 | 09:59 PM
90project5.0's Avatar
90project5.0
Check for pressure before fuel filter and see what you get. Shorten where might be the problem. Have you checked for voltage at the pump connector? Do you hear the pump priming?
Old Yesterday | 02:56 PM
7th Gear
I did ensure that the fuel pump works, and the fuel filter isn't clogged, but I just have no fuel pressure in the rail
Old Yesterday | 09:01 PM
90project5.0
Jump the fuel pump test port, turn key to run position and see if you get fuel to the rail. If not, pull the tank selector switch and verify it’s sending power out.
jwillman
19
Dec 31, 2020 01:16 PM
Shawn Paris
Aug 2, 2016 10:56 PM
JoeVR5
Sep 28, 2015 12:47 AM
78250custom
May 22, 2009 10:05 AM
Koji2528
Bronco II
Dec 3, 2004 02:56 PM
