Reliability of new 7.3L engine and idling
Old May 17, 2026 | 10:39 AM
troverman's Avatar
troverman
Currently looking to replace some fleet trucks (F550 with service body / crane) with new ones. Our current vehicles have 6.7L diesels in them and are 2016 model year steel body trucks. They don’t get a ton of miles but they do idle a lot. The diesels have been mostly fine. Looking to get the gas in the new trucks. Same deal, not many miles but plenty of idling. Are the 7.3’s sorted out now?
Old May 17, 2026 | 05:36 PM
FordExpy486's Avatar
FordExpy486
It seems like idling is still a problem based on what I see on social media on ANY pushrod engine these days with ultra low zinc oils. The 6.6 Cummins have been eating camshafts since the roller lifter change in 2019 if idled, the 6.6 L8T are chewing up lifters and rings when idled, and well we know the 7.3 does as well. The 6.4 Hemi has always had hydraulic lifter issues so don’t even need to address that one. Not sure how the new 6.7 PS and 6.6 Dmax handle idling but Cummins is having major issues with high idle time. I’d imagine the newer Powerstrokes will suffer the same fate as the 6.6 L8T and 7.3 Godzilla with high idle time.
Change your oil based on hours and try to limit it. Idling anything with today’s thin zinc free oils is wreaking havoc on it.
Old May 17, 2026 | 05:56 PM
maxGasser's Avatar
maxGasser
I’m thinking part of why they included the Forged Crankshaft & overbuilt other aspects like 6-bolt cross drilled mains etc is due to ProPower OnBoard 2kW since they recommend using the truck as a generator, the owners manual effectively advocates long duration idle.
Old May 17, 2026 | 06:50 PM
Midwest87's Avatar
Midwest87
You dont need forged cranks for idling or 2kw power.
Itll be fine. Consider 10w30for hot climate.
Old May 17, 2026 | 07:04 PM
1olddogtwo's Avatar
1olddogtwo
That's funny.
Old May 17, 2026 | 08:15 PM
Midwest87's Avatar
Midwest87
My 6.2l had more idle hours than driving hours
If a 6.2 can take it, the 7.3 should be no problem.
Old May 17, 2026 | 08:50 PM
FordExpy486
6.2 has a gerator crank driven oil pump and lash adjusters I believe, I think it has it a little easier than most of the pushrods at idle. Not saying idling will
automatically blow it up, just saying there’s a trend with ALL these hydraulic lifters based pushrod engines….
Old May 18, 2026 | 05:33 AM
troverman's Avatar
troverman
The 6.2 has a conventional gerotor oil pump as stated, and has micro hydraulic lifters at the end of the rocker arms. The 7.3 also has lifters below the pushrods. The problem is too low oil pressure at idle with a warm engine. Ford needs to increase idle oil pressure. A thicker oil would also likely help alleviate the problem.
Old May 18, 2026 | 07:23 AM
saratoga2011's Avatar
saratoga2011
20 psi at hot idle is kinda light IMO.
I've been using 5W40 Delvac-1 since new and have no plans to change as long as it has the SN rating.
Old May 18, 2026 | 08:03 AM
Midwest87's Avatar
Midwest87
Weve had hydraulic lifters for decades, with high idle times, low pressure, and theyve been fine.
The common denominators are thin oil, chinese cams and lifters. Id fix the oil thickness first.
Old May 18, 2026 | 08:31 AM
FishOnOne's Avatar
FishOnOne
This is what I've been suspecting been going on. I know the chinese will sustitute substandard raw materials if you don't monitor them.
Old May 18, 2026 | 09:09 AM
FordExpy486
No we have not. Idle psi on a Chevy 350 or 454 was 35-40 psi, today it’s 10-15 psi. Small block and big block chevys were fed zinc supplemented oil and had flat tappet camshafts. Today all the zinc is removed from the oils and they are running less than half the oil pressure.
Old May 18, 2026 | 10:03 AM
travlnman's Avatar
travlnman
Prepare yourselves for what I'm about to say.....but I mix 50/50 with Valvoline VR1 10w30, and any name brand 5w40 I can get on sale. I don't have emissions inspections, or visual inspections , so if my cats crap out one day...I'll probably just hollow them out and run emulators for the oxygen sensor inputs, an drive it until the wheels fall off...
Old May 18, 2026 | 10:14 AM
FishOnOne's Avatar
FishOnOne
Zinc (ZDDP) has not been removed from todays oil
Old May 18, 2026 | 10:26 AM
FordExpy486
1300-1500 PPM ZDDP was typical until mid 90’s, today’s oils all have 500-700 PPM ZDDP. The reduction started in 1995. If you have a flat tappet you need to put in Zinc supplement in to even give the engine a fighting chance at survival. Today’s oil will kill an old OHV flat tappet small block or big block in short order.
The 454 in my boat from 1995 is flat tappet cam, and I need to put ZDDP in as an add to my oil every year. That’s straight from Mercury Marine. Failing to do so will wipe the cam out and destroy the entire engine in 50 or so hours. Today’s engines are trying to make do with rather junky oil if you really think about it, it’s a miracle they last as long as they do. It’s like taking a foam topper off your hard mattress, everything’s making more metal/metal contact and stress. Unfortunately you cannot put ZDPP in as an add though as it destroys the new catalytic converters.
