Found in transmission pan
Old May 15, 2026 | 12:19 PM
BAD RONALD's Avatar
BAD RONALD
[img alt="Changed out the oem 10r80 transmission pan yesterday. 2017 F150 3.5l with 68,000 miles. This was stuck to the pan magnet.
Anybody know what it is?"]https://cimg8.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x901/20260515_131227_03498789182af58f79fa6d80f451fd7e30 3249f7.jpg[/img]
2017 F150 3.5l 10R80 68,000 miles. Changed out the factory pan and found this stuck to the magnet.
Old May 15, 2026 | 08:11 PM
stephen.osborne1's Avatar
stephen.osborne1
Looks like some sort of roll pin?
Old Today | 07:02 PM
RobertRoberts's Avatar
RobertRoberts
2nd Gear
On the 10R80 that piece on the magnet is usually one of three things: a broken snap ring fragment, a clutch return spring piece, or a bit of hardened steel from a bearing or gear thrust surface. The shape in your photo looks more like a stamped spring/retainer piece than normal fine “fuzz,” which is what makes it a bit more concerning than just break-in debris.
At 68k miles it’s not automatically catastrophic, but I wouldn’t ignore it. If it was just gray paste or fine sludge that would be normal wear. A solid chunk like that suggests something has started to mechanically fatigue inside the rotating assembly.
mrmichael
2004 - 2008 F150
Nov 16, 2025 10:02 AM
6_Gun_72_Ford
Oct 21, 2024 06:36 AM
Sprocket118
Oct 9, 2023 11:05 AM
6_Gun_72_Ford
Jun 26, 2023 06:23 AM
boo-yaa138
23
Jul 6, 2009 02:52 PM
