F O R D VINTAGE TAILGATE WANTED
Old Yesterday | 01:11 AM
Yboo69's Avatar
Yboo69
4th Gear
HI everyone. I'm new to owning my "Old Ford pickup truck". I have a 1989 Ford F150. I want desperately to change the tailgate. Can anyone help me? Lead me in the right direction to finding an interchangeable tailgate for my 1989 truck. I want the vintage tailgate that says F O R D. Is this possible? Are there ways to do this?
Old Yesterday | 06:31 AM
AuroraGirl's Avatar
AuroraGirl
here is a Bullnose (1980-1986) these tailgates CAN work if you match the hardware (do you have cables, you should have cables?) to do this you would need the metal strap design and the cup design features to be harmonized to your bed design.
heres some of the bullnose setups, the one for your year is
1982 is the last year for this
1983-1986
1983-1986
if you consider the large F O R D thats applied via decal to be "vintage" then your truck could have come with it
but if you want the F O R D from like the 70s maybe 80s that is recessed into the sheet metal, you will need to swap beds in order to have the body lines on the bed match the tailgate, or you would need to change the moutning hardware if the 80s beds tailgate were to fit.
Old Yesterday | 06:33 AM
AuroraGirl's Avatar
AuroraGirl
if you dont want the tailgate to obviously not be a match to your truck, you can just use the later bullnose tailgate design with the ford logo. but the appearance wont look right. if you dontc care, go ahead. if you use the bullnose bed, your cab and bed will look odd together but if painted riht it wont be sour thumb in my view because then the bed matches the tailgate. but the fuel filler will have to be made sure to work, not sure about the work for that. and the tailights are differrently wired too, so there would be changes. Otherwise if you have a flat tailgate, yours can have the Decal "FORD" like a lot of other bricknoses had factory
Old Yesterday | 09:40 AM
My4Fordtrucks's Avatar
My4Fordtrucks
If you can find one, base models did not have the stainless trim.
Old Today | 01:49 AM
Yboo69's Avatar
Yboo69
4th Gear
WOW, where do I start. I want my tailgate to look like the one in your picture. What you wrote was so foreign to my ears, but I'm listening. You know so much. So, where do I start. I've heard of Bullnose. So..... let me think. Are you saying 1980-1986 Bullnose tailgate will work? I really dont want to get a new bed, but open to it. I do already have the decals. But, want the stamped letters. Thank you so much for replying. Where do I start?
Old Today | 01:51 AM
Yboo69's Avatar
Yboo69
4th Gear
Hi, what are you saying. Base models. Is there somewhere I can find something that would work? I am new to this.
Old Today | 04:20 AM
My4Fordtrucks
I’m saying a base model Custom or XL would have this tailgate
Probably a junkyard. It looks like the new aftermarket sheet metal is not stamped. Good luck in your search.
Old Today | 06:01 AM
90project5.0's Avatar
90project5.0
If yours has the metal trim in the middle, remove it and fill the holes. Mine has FORD stamped in it.
Old Today | 06:48 AM
My4Fordtrucks
True but that requires bodywork and paint. Maybe the OP or bot can find one in the correct color. I’m confused by the desperation in going from the higher option tailgate to an entry level tailgate.
Old Today | 09:28 AM
AuroraGirl's Avatar
AuroraGirl
1983/4+ only
the brick nose I’m pretty sure had the same look tailgates did they not ?
Or is it from a brick?
Old Today | 11:50 AM
90project5.0
Originally Posted by AuroraGirl
1983/4+ only
That’s what my 90 looks like. Previous owner removed panel but didn’t fill holes..
6t6merc
Nov 12, 2013 07:20 AM
