Our new "Deer Defense" came off of an F250 Bullnose How can I fill in this gap? Watch out Zombies
See if you can find an old hood or other bent body part with lots of flat metal. You can cut some small p[anels to cover the space. Use bolts to attach them in case you have to work in that area later. You can also mount some lights on there for when Bambi decides to do a "Bambo" on you.
I had a similar bumper on an old Dodge. It didn't have the over rider but was handy when the engine started failing. If it sat overnight I has to use Ether to start the truck. The3n if it sat for a few hours. Then every time I needed to start the truck. I finally changed the engine, it got respect even though I didn't have to stand on it anymore.
I will say one thing though, be careful driving it. That oil field pipe will NOT bend if you hit a tree. The truck will fold up instead. Does the main pipe have air fittings on it?
Have not seen any air fittings, it didn't drop my front end like I was afraid it would.
I took all of our strength and a cheater pipe to get it on. I was thinking maybe
diamond plate since we are standing on it. lol Thanks for the input, I'll do some
pondering on the subject.
Diamond plate looks good, but adds weight. You can try drilling and using a tap to thread a hole in the pipe for a Schroeder valve like on your tire to air it up. When I worked in the oil fields, we'd do that, although usually larger diameter pipe, and carry air for an occasional flat or low tire. I've even seen guys add a compressor to air the pipe up for air pressure on the trails. The old Chrysler 2 piston jobs were good for that.
Did the truck it came off of have a winch?
I know some work but I think if it was higher and set back a little the gap would not be that bad.
Dave ----
I would fab a bracket that allows a seat to be bolted on to that bull bar....facing backwards. That way you could at least sit comfortably while you work on the engine.
You are forgetting this is a FORD, not a dodge or chevy! No seat necessary.
Aluminum diamond plate is available at less weight. Bolt on as was suggested. A nice standing platform when you're folded over into the engine bay.
Aluminum is easily cut and drilled unlike steel which takes more effort better cutting tools.
Well, SURE if you want to spend a lot of money. I'm a che...er...thrifty olde pharte. I reuse stuff until I HAVE to spend money. When my grandfather would butcher a pig, he used everything possible. If he could have used the squeal, he would have.
