E350 7.5L RV... timing chain/water pump replacement
Any who, I intended just to come look for where I can get some replacement bolts but guess am getting lazy n soft. so any recommendations of a competent wrench in montgomery co...
1989 E350 Mallard... from Arizona.
Help a brotha out
The only hard part is getting the front oil pan lip gasket installed
You can eliminate that gasket and just use silicone
That makes the job plug and play just assembly with bolts
The right way is to gorilla push the cover down to compress the gasket
I've done it both ways hundreds of times
On a MH chassis it will be easier to toss the gasket
You do not want a repeat repair or a leak
seriously am tryna get the YouTuber Chris (NNKH) to do it. maybe he's too big for the common folks. but I could hope.
last year when I removed the timing chain cover, the chain was broken and I assumed I did that while prying off the cover. Now, however... while preparing to pull off them old sprockets... I find a foreign chunk of metal wedged between the double sprockets. clearly is what broke the chain.
Now Im concerned is there other damage to the motor because we cranked on it quite a bit tryna get her running while attempting to find the leak.I also assumed the fuel pump shutoff was the culprit, but not anymore.
Q. should I look for damage and what do I look for and how? or should I just connect the dots and keep rebuilding?
ok am on a roll now...do you by chance know of a place I could find a good walk through of this job?
ahhhh... everything came apart pretty easy, so just gonna replace bolts and maybe few hoses. should I replace the rad? was thinking put the og back in and flush the system with it and then replace it if necessary, worked fine, just pretty cruddy in there.
The front of the oil pan had been sealed with RTV previously decades back, and it was Pooched-Out. _ Not good.
So I to a rag, a brush and Acetone, and cleaned the area super good after pulling out the old RTV bead.
The repair is now two years old and holding just fine. _ _ _ so you feel better about discarding the gasket on the front. _yep.
Line up the DOTS and go for the Gusto ! _ _ take your time and take lots of breaks for sanity.
When you install the Timing Cover, use the balancer to "Center" the Cover before torquing-down the bolts
I installed the Crank seal at a depth to ride where I wanted it to on the balancer seal surface. I think my balancer has a seal-sleeve too.
Manic will keep you straight.
I used a Cloyes timing set on mine. My timing cover had lots of electrolosis holes, so I replaced it with one from Summit. I had to chase the threaded holes first.
Was the engine overheating Azeez?
I would at least flush the radiator out and go from there
His should have dowels in the block to align the front cover
Your 304 should have had them too
Those dowels are the reason to discard the front pan seal if not pulling the oil pan
I believe the old FE motors are the only ones that need the Damper (sleeve) to help center the front cover
Thanks for the kind words, Greaser
We are all in this together
rewriting this cause I timed out before I could send, sumbish,
Its so nice to get feedback from reliable sources, I really appreciate you guys!
Manic, that truck ran cross country like a champ only drinking some coolant, but not overheating or leaking anything...
I'm guessing somebody hitter with some stop leak that held for the trek from Az to Pa but the season change out west coast reversed it.
I didn't see any dowels on the block but I did mock up the cover and pump... seems pretty straight forward.
Maybe could use a 3rd hand ideally but should be fine.
Gonna try use my phone to get some photographs in here so you guys can see what am lookin at... before I cut that rubber gasket outta there.
"]https://cimg5.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/20260519_122252_98f8348309965d2f5edb767981c6a57a57 f589e5.jpg[/img]
Boom
oooh check this out...
Its the chain popper 3000... should I post it on EBay?
What da heck even is that?!?
Thoughts?
