Fuel Pump To Carb - Metal Fuel Line
Old Today | 04:59 AM
Country Bumpkin's Avatar
Country Bumpkin
I have no doubt that this has been touched on before, but......
Where can I purchase the Metal Fuel Line that runs from the Fuel Pump to The Carburetor on my '72 F350?
1. I DO NOT want to purchase Brake Line, and make my own.
2. I need to make sure it will have the correct fittings on it, and screw on as it's supposed to.
Mine is broken, and I want to replace it.
I've seen a couple online, but not sure if they'll work for my application.
(Is the Fuel Line the same for a 2 Barrel or 4 Barrel?)
Thanks.
Old Today | 05:03 AM
Country Bumpkin
I found this one online, but not 100% sure if this is the correct one:
https://www.sstubes.com/collections/...r.v.price.lte=
Shouldn't it already have the fittings ON THE LINE?
If not, how do you get them on?
Old Today | 05:05 AM
Country Bumpkin
Here's another one I found:
https://www.cjponyparts.com/classic-...9/p/FTC1011SS/
Would that fit my '72 350?
(Currently has 2 Barrel Carburetor)
Old Today | 04:36 PM
1browski's Avatar
1browski
Ive never had a hard line all the way to the carb before. The trucks Ive had usually had the carb end cut off already. I use rubber fuel line before the carb and usually throw an extra inline filter in for the heck of it. Are you using a screw in carb filter on the carb end or fuel line straight to the carb? If straight to the carb, it will need both fittings. Not sure about your first link but the second looks like it would work, if you switched to rubber fuel line.
Old Today | 10:03 PM
WDXPW's Avatar
WDXPW
All ford passenger vehicles had a hard line to the carb from the fuel pump both lines have fittings on them if you look closely factory would need only one as there was a 3" section of rubber hose from the hard line to the factory fuel filter the rubber had GAS in white letters also.
kjw03
Sep 30, 2025 10:38 PM
Highwayman7043
Apr 25, 2025 09:12 AM
Stump41
Dec 19, 2024 07:18 PM
dsrtjeeper
Feb 7, 2011 10:18 PM
kadrocker
Jan 5, 2010 12:27 PM
