Explorer, Sport Trac, Mountaineer & Aviator 1991-1994, 1995-2001, 2002-2005, 2006-2010 Ford Explorer
No Crank No Start Assistance
Old Mar 19, 2026 | 10:06 PM
TinoTheGreek's Avatar
TinoTheGreek
5th Gear
Hello all 👋 Hope all is well. I've done so much research but can't seem to figure out this issue.
I have a 2010 Ford Explorer that sat for some time because of transmission issues. I used to start the engine from time to time to let it run, but one day it wouldn't crank over and the instrument cluster was very upset, lit up like a Christmas tree.
Silver Synthetic rubber Tread Carbon fibers
Silver
Come to find out, the harness running along the right side frame rail along with the frame to body ground were chewed through. Well, I fixed the harness and replaced the ground strap and nothing.
Electrical cable Electrical wiring Wire Speaker wire Heat-shrink tubing
While the instrument cluster is less angry, it still has some lights up. Still no crank no start. The starter works fine, I can jump the relay and the engine cranks over. The fuel pump is kaputs unfortunately probably form sitting. There is no issue with the security system. There is no issue with the Safety Neutral Switch. There were some blown fuses but those have since been replaced. When scanning I do get multiple codes along with a C2780-60 code which indicate to me that the GEM/SJB is possibly bad. I tried reprogramming it so it can come out of "Manufacturer Mode" but no good. Tried that 3 times using an Autel and all three times were successful supposedly but it's still in Manufacturer Mode.
Is it possible that the GEM/SJB Module is bad? Is it possible that the PCM is bad? At the moment these are the only conclusions I can come up with. I'd like to add that I tried to program two new keys and after upon completion the explorer still didn't recognize the new keys.
I'm ready to rebuild the transmission now and would like it to start again lol
Old Mar 20, 2026 | 08:39 AM
shorod's Avatar
shorod
Did you check all the fuses to see if maybe a fuse or two blew when the critter was chewing through the wires?
-Rod
Old Mar 20, 2026 | 09:15 AM
TinoTheGreek
5th Gear
-Rod
Yeah, checked all. The fuel pump fuse had blown but I replaced that already. Otherwise, all the other fuses were still good. Both in the Engine bay fuse box as well as the interior fuse box.
Old Yesterday | 07:16 PM
raymc0567's Avatar
raymc0567
4th Gear
I'm new to this forum & wondered if you ever found a solution. I have an 2004 with a similar issue that I will create a post on shortly
Old Yesterday | 07:42 PM
TinoTheGreek
5th Gear
Hey there 👋🏽 the issue was in fact the SJB Module. No matter who tried to reprogram it, it wouldn't work. I matched the Part Number and ordered a good used one, had it reprogrammed and all good after that 💪🏽 Hope this helps 🙏🏽
Old Yesterday | 10:55 PM
raymc0567's Avatar
raymc0567
4th Gear
I have an ob2 reader & can't pull any codes.. what is the SBJ?
I'm going to check along the frame rail also
Old Today | 09:47 AM
TinoTheGreek
5th Gear
The SJB is the Smart Junction Box. Its the interior fuse box under the dash by the steering wheel. The fuse box also doubles up as a module kinda like a body control module so it's a smart unit. Instead of being just fuses it has a motherboard and serves other functions.
You said you can't pull codes? Have you checked all the fuses? There are fuses for both the OBD Port as well as the PCM in the engine bay fuse box.
Old Today | 11:59 AM
raymc0567's Avatar
raymc0567
4th Gear
Yes, when I bought it a couple years ago, the radio fuse was drawing or "running all the time," I bought a "Add a fuse" kit to fix it. I only checked a few of those fuses but checked all the fuses & relays under the hood which checked out fine
Old Today | 12:45 PM
TinoTheGreek
5th Gear
Have you always not been able to scan the explorer? Or is this a recent thing?
KensF750
Large Truck
27
Mar 17, 2025 11:15 AM
XbigXredX
Jan 12, 2025 01:05 PM
mccoykevin60
Dec 30, 2024 01:20 PM
Patrickgraper13
1997 - 2003 F150
Apr 3, 2023 01:39 PM
Shadeey
Mar 9, 2023 11:09 AM
