2012 f350 super duty stalls after running for 5 minutes. I've replaced fuel pump...fuelnpump modulator...crankshaft positioning sensor...camshaft positioning sensor. And there are no codes. 6.2 gas engine
What exactly is it doing when you say it stalls? Does it chug and then die or just act like someone turned the key off? And then does it start right back up or do you have to leave it set for a while before it restarts? I had a similar issue I fought for a couple years and mine would die while driving and usually start back up and it may run a week or couple days. It finally started doing it all the time. But the funny thing was by the time I would get the ness tools to check it ,be a test light, spark tester etc ot would always start. I put a super chip in it when I bought the truck new in 2002 and this was about 7 years ago U was having the problem. Someone in here had the same type of trouble. Well it finally died and wouldn't restart. I had no signal to the fuel pump and also no spark. So I dropped the computer and took the chip out and it fired up been running ever since.
I contacted super chips cuz the current chip for a 2002 V-10 was a different number then mine was. I asked why the different number and if they had any issues with them . You already no the answer, of course not and he didn't know why the different part number now. Well I've been driving it now for over 8 years and hasn't shut off once !
