7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
7.3 oil change
Old Jan 7, 2026 | 05:18 AM
roberthleeii's Avatar
roberthleeii
7.3 oil change
It is about time for my first oil change and I want to make sure that I am getting the right oil and filter. (2026 7.3)
Oil filter:
Motorcraft FL-820-S Oil Filter Motorcraft FL-820-S Oil Filter
Oil:
Mobil 1 Motor Oil 5W-30, 5 Quart | Full Synthetic | Truck & SUV | Pack of 2 Mobil 1 Motor Oil 5W-30, 5 Quart | Full Synthetic | Truck & SUV | Pack of 2
Air filter:
Motocraft FA1950 Motocraft FA1950
Cabin air filter:
Motorcraft - FP-92 FP92 Cabin Air Filter Motorcraft - FP-92 FP92 Cabin Air Filter
I linked to Amazon. They seem to have the best prices and that is where i am ordering from. I am also buying an air filters just to have on hand and want to make sure i am getting the right ones there too. I am planning on keeping an extra of everything on hand.
Sorry if this is a dumb question I just want to make sure I am getting the right parts before I order.
Thanks in advance,
Robert
Old Jan 7, 2026 | 05:29 AM
kry226's Avatar
kry226
Same as what I use.
Old Jan 7, 2026 | 09:17 AM
OBS460's Avatar
OBS460
I've gotten 40k miles out of my air filters by just blowing them out with an air compressor.
Old Jan 7, 2026 | 11:01 AM
ssls6's Avatar
ssls6
People will debate the oil capacity but use 8 quarts and check it the next day when engine is cold on level ground. You can decide from there.
Old Jan 7, 2026 | 01:07 PM
Charlie98's Avatar
Charlie98
That sounds like a swell idea, until you understand you are damaging the filter media by aiming compressed air at it. Same idea with pool filter cartridges and a pressure sprayer as well.
Old Jan 7, 2026 | 01:15 PM
roberthleeii
$30 every 10k miles for an air filter is cheap insurance for some of the dusty environments I am constantly in. Just like i probably don't need to change my oil at 1,000 - 1,500 miles, i am ; and I probably don't need to change my oil every 5k miles after that, i am.
Old Jan 7, 2026 | 01:25 PM
OBS460's Avatar
OBS460
Oh my gosh the sky is falling!!! This is a ridiculous take. Are you standing over my shoulder as I blow air through my filter backwards? What is the air pressure of the 7.3 turning 5k rpm and traveling 70mph into a headwind? Is that damaging the filter media?
Old Jan 7, 2026 | 04:35 PM
350Recon's Avatar
350Recon
Oil filter: Motorcraft FL-820-S Oil Filter
Oil: Mobil 1 Motor Oil 5W-30, 5 Quart | Full Synthetic | Truck & SUV | Pack of 2
Air filter: Motocraft FA1950
Cabin air filter: Motorcraft - FP-92 FP92 Cabin Air Filter
Thanks in advance,
Robert
Good to go on the parts. I keep spares on those myself.
Old Jan 7, 2026 | 06:21 PM
roberthleeii
(dumb question alert)
Is there no fuel filter to change?
Old Jan 7, 2026 | 06:45 PM
OBS460's Avatar
OBS460
It's in the tank and Ford claims it's a "lifetime" item just like the coolant.
Old Jan 8, 2026 | 12:36 AM
Charlie98's Avatar
Charlie98
And I KNEW you would be along to dispute me...
You do you. I'm telling you... if you are blowing compressed air through the air filter pleats, you are damaging the media. How much that may be, I can't tell you... because, no, I'm not looking over your shoulder.
Instead of the smart reply... you engage your brain. Air traveling through a filter at highway speeds is nothing like compressed air, focused into even a broad point, let alone a pinpoint blast.
Old Jan 8, 2026 | 09:34 AM
OBS460's Avatar
OBS460
Why wouldn't I not dispute your ridiculous claim. You act like An air compressor is going to be blasting 200psi of air at a pinpoint spot and will rip the filter apart. I can promise it doesn't damage the filter media. I can't imagine living my life with the level of worry you carry around. You just know I'm damaging the pleats but you can't say how much because you have no clue. I never said I was holding an air nozzle point blank and shooting "X" psi of air at the filter.
It isn't just air traveling at highway speeds. the engine is a giant air compressor. It creates a vacuum and sucks so much air through the filter that it creates a whistling sound. If the engine is spinning 5k rpm it is sucking a massive volume of air. If you engaged your brain you would understand that an engine is a massive air compressor and air doesn't just go through the filter because of the speed it's traveling but is forced through by the vacuum created by the engine also.
There is zero reason to engage your ignorance any longer. Go back to worrying about something else that is frivolous.
Old Jan 8, 2026 | 03:53 PM
charlie g's Avatar
charlie g
FTE Community Team
lets keep it clean
Personal Conduct .
Post language and material suitable for the home or office. Do not post foul language, political content, racial epithets or sexually explicit content in any form. personal attacks will not be tolerated . Posting for the purpose of gaining access to additional features of the site is not allowed
Old Jan 10, 2026 | 03:01 PM
75 F350 1Ton's Avatar
75 F350 1Ton
Install a high quality filter guage and change your filter when it has moved half way. You will be surprised at how much dirt will be there, and still show good. Believe it.Use the air nozzle for your shop vac filter.
Old Jan 11, 2026 | 06:43 AM
Blueridge73's Avatar
Blueridge73
All those parts look good, can’t go wrong with motorcraft.
Haven’t done the cabin filter yet, lots and lots of Marlboro lights been thru that poor *******. Makes me think between coughs.
