Does anyone have the engine specification page? In the Ford workshop manual it would be Section 03-01D-00 General Information. Not sure if there is an old book equivalent. I'm looking for information such as acceptable crankshaft run out, bearing size, valve lash, etc. I recently switched from working at the dealership to heavy equipment so I no longer have access to the workshop manual. I need the information for an engine rebuild.
I'll assume it is in the factory manual I have out in my garage, I can try and scan a page for you later today or tomorrow, but the family is home and I'm being called to the kitchen for dinner.
I may completely forget, so if noone else posts it in a day, PM me so I get an email reminder...
This is what I found in the ShopKey files. Does this match up with what is shown in the factory manual?
Recently I bought the Hanes book for this generation of truck and the supplemental diesel book. I also went back to my old dealership and had one of my buddies print out the section I was looking for. I was surprised to find that the Hanes manual was very accurate. I haven’t cross referenced every measurement but it was better than I expected.
All I have is a Cheater's guide. I doubt it even has that information. Do you plan on doing the machine work yourself during the rebuild?
A mix of both. I have a machine shop I like that I’ll take to for any actual machining or if I have questions. But I like to measure and double check their work as well as make sure everything is within spec when I put the engine together.
