96 e350 7.3 engine wiring harness
Old Jun 12, 2025 | 10:48 PM
rrhu's Avatar
rrhu
2nd Gear
This is probably a long shot, but does anyone happen to have a clear picture of the engine wiring harness for a 96 e350 7.3 routed OEM? I’m finishing up my wiring harness rebuild and about to install. I’m feeling confident that it’s gonna be solid but I’d love to see a photo of the exact routing. I stupidly forgot to take a picture before pulling it out and while I had the valley empty. I’ve found an illustration that is helpful, and a clear photo would be extra helpful.
Thanks in advance!
Old May 13, 2026 | 09:52 PM
Thelegendl23's Avatar
Thelegendl23
02-03 non ca https://a.co/d/070ZoBLa
E99 harness https://a.co/d/00Qzk28r
ca model with gpcm instead of relay https://a.co/d/0aoKkBkz
Pre 98 harness https://a.co/d/00DZaXSA
Old Yesterday | 10:14 AM
knottyrope's Avatar
knottyrope
first three links go to super offers dot com
I suggest using the actual link when posting as many wont click a link like that since it can go anywhere
Old Yesterday | 03:05 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
@knottyrope
Try clicking the links on a different device. I'm concerned that your device is redirecting these links to a website other than Amazon.
I've lowered security settings to look at all four links, and all four went to Amazon listings consistent with the Thelegendl23's verbal description and intended contextual contribution to the thread (which is not necessarily applicable or relevant to an E-350 van that the OP has.)
The short hand url a.co is owned and used by Amazon.
If your current device is redirecting to another website, there could be a trojan in your device.
I will continue to investigate with other browsers, but in two trials thus far, I have not found a problem with the links as posted, other than the wire harnesses being for the F-Series, rather than the E-Series.
Old Yesterday | 03:18 PM
Shadowfax7.3's Avatar
Shadowfax7.3
Trailering
I can't imagine it's too much different than an F series, most everything is on the top of the motor in the valley in front of the fuel bowl. Starter solenoid lead runs to the starter solenoid on the passenger fender and the lead with coolant temp, oil pressure, and CPS run down the front of the motor in front of the HPOP behind the belt etc. I just did one on my F250 and it was hard to get anything in the wrong spot.
Old Yesterday | 03:35 PM
Thelegendl23
Originally Posted by Y2KW57
@knottyrope
Links were copied directly from Amazon as a share. Also I had several more there including the e series but they didn't post. Hey that's cool was just trying to help. Only been working on 7.3s for 30 years is all.
Old Today | 09:10 AM
knottyrope's Avatar
knottyrope
turned on my popup blocker and now it dont redirect them
no other sites im on do this and this is a new pc
moreford
Dec 8, 2014 11:32 AM
earlybroncoboy
1966 - 1977 Early Broncos
Feb 1, 2006 09:44 PM
tskinner
Jan 3, 2005 02:15 PM
shortbed1
May 28, 2003 10:58 AM
