FTN’s LED Sealed Beam Headlights
Old Mar 4, 2025 | 09:59 AM
FordTruckNoob's Avatar
FordTruckNoob
So the LED sealed beam units I have been rocking since 2019 have finally had one element fail. I figure technology has had to improve in the intervening years so now I’m looking to install this one:
https://a.co/d/96BBPgc
What do you guys think? I will remember to document the modification of the aero housings this time.
Old Mar 4, 2025 | 11:32 AM
Dan V's Avatar
Dan V
The Noob is having seggsy illumination now!
Old Mar 4, 2025 | 03:15 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Leonard,
I just put a set of those in my '90 4Runner. They are amazing for cutoff and the amount of light they put out down the road. Out here in the desert they are a life saver. I like them do much that I have been entertaining doing the retrofit into the aero housing like you did previously. My only concern is I switched to '05 style lights years ago which have no left/right adjustment. Those lights have a stepped cut off so the left/right adjustment will be critical for proper adjustment. I can get some pics of the pattern if you would like to see them. I will be watching for your documented update as you have been into the aeros before. Thanks in advance.
Old Mar 4, 2025 | 04:53 PM
Wes444's Avatar
Wes444
I put those HW Star 2022 models on my Vette back in late 2021. Amazing light output and cutoff. I can't comment on the 2025 model, it looks like they changed the design quite a bit. Even on the CorvetteForum people have loved the 22s I recommended. I haven't heard too much about anyone's experience with the 25s yet. But for $79 back then it was definitely worth it
Old Mar 4, 2025 | 09:14 PM
FordTruckNoob
Thanks for the feedback fellas! Order placed.
Old Mar 7, 2025 | 10:59 AM
glovemeister's Avatar
glovemeister
What do you mean, you take those apart and mount them inside a superduty headlight housing?
Old Mar 7, 2025 | 01:29 PM
Dan V's Avatar
Dan V
Indeed he does.
Old Mar 7, 2025 | 03:05 PM
FordTruckNoob
I sure do. Here is the current iteration.
Old Mar 8, 2025 | 10:58 PM
JoshHefnerX's Avatar
JoshHefnerX
I'd be interested in seeing how you've done this if you're willing to take some pics when you swap them again.
Old Mar 9, 2025 | 08:55 AM
FordTruckNoob
Sure thing. I intend to fully document the process this time.
My challenge this time is to come up with better fixturing to make the cuts more accurate relative to the datum.
Old Mar 10, 2025 | 08:47 AM
Dan V's Avatar
Dan V
This might work..
Old Mar 10, 2025 | 08:49 AM
FordTruckNoob
Originally Posted by Dan V
This might work..
Did you know they also make the GameSphere?
Old Mar 10, 2025 | 11:41 AM
Dan V's Avatar
Dan V
They make fishing reels as well.
Old May 8, 2025 | 01:54 PM
FordTruckNoob
I’m finally getting around to figuring out the fixturing needed to cut the back off the aero housings.
Old May 8, 2025 | 03:10 PM
JoshHefnerX
Gonna be a trick to pin that down so it doesn't move without damaging it.
