Short version. F-350 long bed is just a nicer riding truck than a F-250 short bed.
So we did the travel trailer thing. Started out looking for a lil camper. Then my wife saw bunks for the grandkids. So of course we got that one. 35’ 5th wheel, about 10,200 lb loaded and scaled.
We setup our ‘22 F-250 CCSB 7.3 3.55 with all the goodies to tow it, but ended up needing more payload. Power etc was never an issue and I really rather enjoyed towing with the 7.3. But with only a couple hundred pounds of payload left on the 250 we decided to fix that and go with a long bed while we were at it. Add in grandkids and their junk and we were done as far as payload goes. Hence the F-350.
What I really didn’t expect was how much better the ‘24 F-350 CCLB 6.7 rides when empty! It’s night and day. I ASSUMED (yeah) that the F-350s would be way harsher than a F-250 and never even toyed with the idea back when we got the F-250.
So if you go truck shopping don’t shy away from looking at the F-350. You might be pleasantly surprised.
Your comparison is a bit apples to oranges. F350 diesels weight much more than similarly equipped F250 gas trucks, they hold the road better even with a little stiffer springs and one extra leaf on the back, that extra 700-800lbs on the front axle make a difference. The longer wheelbase makes a huge difference too. It should be no surprise that a diesel F350 CCLB rides better than a gas F250 CCSB.
My 22 F250 with the 7.3, 4wd, and CCLB rides like a half ton and still has about 2800lb of payload with the 10k payload package.
That's good to hear because my 2019 rides like GARBAGE. Haven't been in a vehicle that rides this bad since I had a 1992 Jeep Wrangler YJ with the leaf springs front and rear.
We were pleasantly surprised when my 24 F350 DRW CCLB 7.3 came in. The ride was so much better then our prior chevy 2500 and comparable to the 2017 F150.
We were expecting a rough ride but didn't really have a choice with the camper we decided on.
We take ours on solo trips on occasion. The highway ride is really good. Towing our 14,700 pound fifth wheel is also pretty darn good. I know it's back there but it handles well. I have a Reese Goose Box on our fifth wheel. It has an air bag and 2 shock absorbers which I think helps some. I also changed the factory shocks on the truck to a set of Fox 2.0 which give a little softer ride but also hold up well for towing. I think the longer wheel base does make a difference.
Can confirm, I test drove a 2021 F250 short bed diesel a few years ago, rode like crap.
My 2024 F350 7.3 gas long bed is unbelievably smooth for this size of a vehicle. I had a Ram 1500 Limited with the air suspension before this truck and the ride on it was fantastic.
Payload not so much which is mostly why I upgraded but I thought I was going to lose a TON of ride comfort going from that to my F350. I obviously definitely lost some but not nearly as much as I thought I was going to. It's rather astonishing.
I also think my 2024 F-350 6.7 8’ bed rides pretty good for a 1 ton truck. I put some 7500 Air lift bags on because of our 5th wheel. After the air bag install, I think it stiffened up the ride a little bit.
I've had 2 gas F250's, an 18 gas F350 CCLB and now a 24 diesel F350 CCSB. Both of my F350's have/had a better ride than either of the F250's and all were equipped with front plow springs.
And our 2021 F350 SC short bed rides way better than our 2018 F250 SC short bed did. Equipped nearly identically. Some changes clearly to ride quality. So it might be year change as much as long vs short. Not sure what your "year change" was.
the mid cycle refresh in 2020 seemed to have made a difference between the 17-19 and 20+ when they lowered the trucks and probably tweaked the springs a bit, then the 2023+ are supposed to have had some further tweaks.
The pattern seems to be
-the longer the wheelbase, the better it rides
-the heavier the truck the better it rides, so for same weight class, trim, cab/bed configuration, the diesel will probably ride better than the gas one, even if the diesel is in the next weight class up compared to the gas one.
-if all else are equal, 23+ are reported to ride a bit better than 20-22 which are in turn noticeably better than 17-19 which are in themselves better than previous steel body SDs, especially the pre-2008 SDs with the shorter rear leaf springs.
