Time for new injectors...need opinions/advice
My 2002 starts just fine but she is such a dog. I put an Adrenaline? HPOP on a few years ago to replace the original unit, a new turbo center section last year (helped at highway speeds) and Riff Raff up pipes.
I have (non functioning) Power Hungry tuner thang in the truck (need to diagnose it). I have in-line fuel filters and replaced the LPFP maybe 40k miles ago.
She has around 230k miles on the original injectors. I like preventive maintenance. I've done a lot of it. Practically everything other than motor has been replaced at this point.
Should I just default to FullForce?
I'm not interesting in making this clumsy old truck into some straight-line killer. Its just a work truck. I don't want to push the transmission harder than it can handle or get horrible MPGs. I just need her to run a little better off the line. She feels tired.
https://www.riffraffdiesel.com/full-...sel-injectors/
Well yes .. The Hydra took a dump a year ago plus. I do need to get her going again.
Is this the rosewood in question?
https://rosewooddieselshop.com/
Why is it the first time I'm hearing about rosewood?
that is the Rosewood we are talking about.
as to why?
you have not been following the Forums enough,
he is talked about everywhere, and on the social media groups also.
a toss up between Jim and CNC
Thx for your thoughts. Appreciate you gents.
160/0 or 160/30 if you want a little more pep. Or just factory rebuilds. He will walked you through what you want in the phone and reccomend a size to you based on what you want to do with the truck.
The following 2 users liked this post by ESwift:
Drop if off at his shop and let him rebuild your original ones, if that's geographically possible. That's what I plan to do here before too long but he's only a couple hundred miles from me.
