Adjusting exterior mirror
How do I increase friction holding lower mirror in place?
When I wash my F250 Lariat, it is easy to move the lower mirror when drying them. Is there a way to increase the friction which holds the mirror in place? Below are holes under the housing showing the cameras and don't know if those are weep holes for rain or if there is a screw/nut I can tighten to keep my mirrors in place once adjusted.
Thank you for any suggestions.
Any of these holes allow adjusting mirror friction grip?
So this is the tension system for the lower towing mirror. The torx screw is as tight as it can go. There is no way to increase the friction so that the mirror stays in place more securely. You could remove the metal center and try to bend the arms to get more tension but I figured I would just screw that up so I just left alone.
As to tightening it up, how about slipping something between the metal tabs and the nylon tension piece?
Maybe some tubing of some sort?
If you look at the video I posted before the photo of the mirror friction system, there is a demonstration on how to pop off the mirror. It is quite easy, you just have to be gentle. That white nylon piece in the center applies pressure to the black plastic piece surrounding the white nylon. It is the black plastic part that the mirror clips onto. So to make the movement require more force, you would need to wedge something between the white nylon and black plastic.
Of course, were it me, I would bend the metal tabs to make more tension.
tomtoc
08-02-2007 06:53 PM
