Parking brake light
Parking brake light
2005 F150 XLT 4.6L 4X2
The parking brake lamp stays on all the time. The dealership has replaced the relevant sensors and says the wiring harness is the culprit.
I'm wondering if one of the connectors in the harness is failing, and if I can jumper around the faulty connector.
Does anyone have an experience with this problem?
I'm thinking out loud trying to get a handle on what's happening in the circuit. If I goof any of these thoughts let me know.
During proper operation, when the parking brake pedal is pressed, it moves a switch which opens and allows a current to flow through the wiring harness and then to (I'm guessing) some module or the ECM/PCM or directly to the indicator light.
Since the circuit is malfunctioning and the indicator light is on constantly, then either
(a) the switch is sticking open
(b) there is a short to power in the circuit after the switch
(c) there is an internal short in the circuit allowing power to bypass/jump the switch
(d) ????? [please fill in other possibilities]
Am I anywhere close to saying this correctly?
The following 2 users liked this post by Fifty150:
Brake light won
Rubber bumper on back of E brake pedal. Note hole in the middle.
Switch showing pin that disconnects wire from being grounded to frame when brake released/off.
Switch with wire disconnected.
Hardened glue filling hole on top of rubber bumper.
I pulled the instrument cluster cover tonight and wiggled the connector and the light went off. I've got the cluster out and apart and will get some solder to hopefully complete the repair tomorrow.
From when the dealership had worked on it previously there was a water bottle cap still stuck in front of the connector to try to stabilize the connection and keep the light off. 🙂
Yes, I don't have the problem with the brake light staying on or randomly comming on while driving. You can see how the end of the pin caused a recess in the rubber bumper on top of the hole in the middle of the bumper. You could do any number of things to fix it. Glue, a small plastic or metal patch glued on top.
