1969 Ford F250 Crew Cab Full Custom Build
Old Jul 31, 2021 | 10:13 AM
IML726's Avatar
IML726
I have a 1969 Ford F250 Crew Cab that I bought in 2017. The previous owner said it was a utility vehicle for the railroad in AZ. It came with a SBF 302 and a 4 speed manual transmission. The original plan was for a modern upgrades and keep as a daily driver. That plan morphed into a full custom build. It now sits on a new bagged/body drop chassis from Acme Chassis Factory of Houston, TX. It has a 2019 Gen 3 Coyote with a 10R80 transmission. The brakes have been upgraded to Wilwood 6 piston disc brakes. It uses Accuair Endo CVT with E-Level and secondary 5 gallon tank for air management. The wheels are Hot Rod by Boyds Chinook, 24x9 and 24x15. It has complete stainless steel hardlines for the brakes, fuel, and air suspension. It also has Ultimate Headers and a custom 3" stainless steel exhaust with FlowMaster mufflers.
Old Jul 31, 2021 | 10:15 AM
IML726's Avatar
IML726
Frame
Old Jul 31, 2021 | 10:16 AM
IML726's Avatar
IML726
Chassis
Old Jul 31, 2021 | 10:17 AM
IML726's Avatar
IML726
Body was sand blasted and epoxy primered.
Old Jul 31, 2021 | 10:18 AM
IML726's Avatar
IML726
Cab Mounted to the frame
Old Jul 31, 2021 | 02:52 PM
Lrrr-RulerOfOmicronP's Avatar
Nice! It looks great!!! Is that a coyote? Did you buy or build the frame?
Old Jul 31, 2021 | 03:29 PM
IML726's Avatar
IML726
It's a Gen 3 Coyote with a 10R80.
The frame was built by Acme Chassis Factory. It was their first Ford Crew Cab frame.
Old Jul 31, 2021 | 05:38 PM
FoPar1972's Avatar
FoPar1972
IML726
The frame was built by from Acme Chassis Factory. It was their first Ford Crew Cab frame.
oh so just a little pocket change then... Looks great so far, should be amazing when done. The tailgate in the rendering looks like my other custom tailgate I still need to finish.
Not exactly but very similar. Good luck with the project, ton of work but worth it in the end.
Old Aug 2, 2021 | 09:15 AM
Greaser007's Avatar
Greaser007
A very nice build ! I also did like the graphics of the completed truck. (i've never used photoshop).
Those guys fabricated quite an involved chassis. Once the rear bed tubs are in place at least you'll have room remaining for a cooler.
Old Dec 15, 2021 | 01:18 AM
IML726's Avatar
IML726
Update 12-15-2021
Current status. First time with the front end on since the truck was taken apart. Waiting on hood hinges to check clearance for the intake manifold. The hood will need some work to clear the manifold.
Firewall is being finished up. Placed a Kugel Komponents remote master cylinder behind the dash bc there wasn't enough space due to the engine sitting higher. We'll also use Wilwood remote brake fluid reservoir. Waiting on the Restomodair Haymaker to determine fitment behind the dash.
Lots of sheet metal work left to do.
Driveline Tunnel
Trique Mfg Easy Latch
Old Dec 15, 2021 | 08:43 AM
cstoyer's Avatar
cstoyer
Very cool. Build cost are surely a out of range of my pocketbook but I applaud the drive to do what you like. Keep up the work.
CStoyer
Old Dec 15, 2021 | 11:48 AM
smoky_diesel's Avatar
smoky_diesel
Definitely 'full custom'. When do you think it will be complete? looking forward to updates.
Old Dec 15, 2021 | 11:56 AM
IML726's Avatar
IML726
I'm hoping by SEMA 2022 but there is no rush.
Old Dec 15, 2021 | 12:00 PM
IML726's Avatar
IML726
CStoyer
It wasn't originally planned to be a full custom, but it went that way when I bought the frame. It's been 2 years since we started the project. It's a lot of saving and then mass purchasing of parts.
Old Dec 22, 2021 | 11:24 AM
Brad Brown's Avatar
Brad Brown
What was a frame like that worth? I love it.
