48-52 door hinge pin question
I have the doors on using a set of pins I bought on eBay, but they are not long enough to catch both sides of the mirror bracket. They are missing the oil groove and mic out at 0.280ish.
I have a set of NOS pins and a set of DC repros long enough to catch the bracket, with the oil groove, but they seem too big for the hinge. They mic out at 0.285ish.
Would you use a round file file to clean any burrs, primer, rust or get a 0.285 reamer?
CG ford appears to have a set of stainless pins long enough at 0.280, but I would rather stay away from stainless in this application.
Jonathan
Jonathan
I think I would chuck head of the pin in a drill and run a little emory cloth up and down the shaft before I ran a reamer through the hinges, unless there was a problem with the hinges. I don't think it would take much to file off .005 to make a smoother fit and keep the doors from binding.
That is the way they are supposed to fit. The serrations keep the pin from turning and hold it in place to prevent it from turning and popping up (and out). Tap into place with a hard faced rubber hammer or pull it down with a C-clamp.
I think this is a first!
I've been around this board for a little bit of time now and I think this is the first time I've ever seen someone have a problem getting the pins in...LOL
Normally you can't get the little buggers out.
When I did mine I had to "set" them in place with a mallet. One or 2 decent taps usually does the trick
Good luck
Bobby
Good luck
Bobby
Are the serrations what are being called "oiling grooves"? I have never seen pins with a spiral oiling groove, even tho that would be a great idea.
Yes the pins were tight in the cab hinge. They appear to be tight in the door hinge but I think that is because of high build primer. I am going to clean then up with a fine round file and give it another go.
Attached are pictures of the pins.
