cyl 7 misfire and coolant in the plug well
My '11 Crown vic with 270k miles suddenly started running rough mostly at the lower end of the gears. By the time you got into o/d the whole car shook. Scan tool gives me P0307 cyl 7 misfire, and P0316 misfire upon startup. So I pull the coil on 7 to find a pool of burnt smelling coolant about 2" deep. Siphoned and blew it out and removed the plug to find it's electrodes fouled with a thin coat of something shiny and black. Rubbed off without much effort. The plugs are about 4 weeks and 1500 miles old. Pulled cyl 6 coil right next to it and found a lot of white particles about half the size of rice stuck to the sides of the plug well walls. Seemed odd as I'd just blown out all the plug wells a month ago. Blew it out again and removed the plug to reveal electrodes that were coated slightly white. This plug had a ring of a black just south of the hex part. Looked like darkened sort of coagulated oil. Wiped off easily.
The car drives much better now after blowing the antifreeze out of the plug well but the miss is still there. So glad as this might buy me some time to get this figured out.
I'm not even sure how it's possible for coolant to get in a plug well. Any ideas, head gasket maybe? What's my next step in investigating?
Received 3,107 Likes
on
on
on
there really only are two ford, and dorman. they cost about the same.
ford manifold for $196: https://www.tascaparts.com/oem-parts...02bC12OC1mbGV4
and you can get a dorman manifold off evilbay for $175
Thanks for the link TJC. Cheapest I’ve found it so far was 269 so as long as this is OEM I’ll get it from them.
Do you know if that front aluminum part is available separately? My leak seems to be coming from between the aluminum and plastic part of the manifold. If I could just replace that gasket it would make things much easier
on
on
bradleyheathhays
11-15-2018 09:29 PM
wcreay
03-01-2006 04:02 PM
