2007 vs 2008 Spring Buckets + Any for sale?
Does anyone know the actual differences between the two buckets?
Some places say they are all the same, but obviously Ford has completely different part numbers. They seem to be the same, but I can't quite tell.
Also, if anyone has a set/are parting their truck, please holler. Especially if you are in the bay area.
Thanks!
Thanks!
They are different, the bolt hole pattern is different and the 08-? Has a dimple in the middle.
2005-2007 notice the three holes on the right and two on the left and no dimple in the center.
2008- 20?? Notice the two bolts on the right, one in the dimple in the middle and two on the left. Also in 08 Ford moved the brake line mount from the spring bucket to the frame.
Hope this helps, not sure if anything dimensions wise changed between the two but if your needing to replace yours just get the correct year and you will be good.
Hanger53
07-27-2019 09:56 AM
ryanissamson
11-11-2018 05:05 AM
F100 Mechanic
02-06-2016 01:11 PM
