Limited Slip vs Electronic Differential for a Farm Truck
I am considering purchasing a new work truck for a commercial beekeeping operation. I was considering the F350 Super Duty Flatbed Chassie with payload of 12,700 pounds. Blueberry fields can get pretty darn boggy. Honey Supers can weigh up to 120pds. After reading through the one thread for limited slip vs. electronic slip differential I am still confused which one would be better for muddy situations. Any advice is much appreciated!
I prefer an open diff with selectable differential lock. I like the open differential in winter for driving down the road at speed. Rear end doesn't come around on you as fast.
My last truck had the limited slip, and worked well but needed a rebuild after only thirty thousand miles. Was covered under warranty but still a nuisance .
If you need wheel speed to make it through then maybe the limited slip as I think the electronic locker kicks out after a certain mph. But maybe that locker speed will be enough.
The factory "limited slip" offered by the Big Three for the past 40 years has never been a favorite of mine. As stated, the clutches always wear out rather quickly, leaving you with little rear end locking capability when you need it. Would suggest the Electronic route or Torsen (if offered).
The only thing worse than the "limited slip" clutch-type differential is a vehicle equipped with the "Traction Control" via ABS system, had one experience with one of those in a Dodge in the mud, was pathetic, will never do that again.
Get 4 wheel drive. The locking diff will leave you stuck, 4 wheel drive will not.
I've tried dozens of times to just use the locking diff, on wet grass, inch deep mud, loose gravel, dry grass on a slope, snow & ice on the level. Every time I've been stuck, spinning. Put it in 4 wheel drive, pulls thru no problem.
edit: I was wrong, apparently on the 250-550 you can engage at any time.
E-Locker is real Nice.... 4x4 is best in the slippery stuff.
remember.. ( many do NOT ) in the slippery stuff.. drive like an EGG is between your right foot and the gas petal... little use of power will get you out... 2 wheel or 4 will drive...
also No factory 4x4 is TRUE 4 wheel drive.. unless both differentials are LOCKERS.. and they are NOT. so at best.. its 3 wheel drive. if you have E-locker in the rear...
Originally Posted by SuperDutyScaler
Order the truck with 4.30 gears and e locker. Then the day you pick it up go to your local tire shop and buy a real offroad tire for that truck. If you stick it after that then it's your own fault
The e locker acts as an open rear end when not engaged, helping with tire wear. But I've yet to have a situation where the e locker worked any better than the traction control, which applies brake to the spinning tire, transferring power. Almost every time I have tried using the e locker, I ended up using 4wd.
Growing up on a farm, I always believed if you need 4wd on a field then you shouldn't be on the field. If it's too soft for a 2wd pickup then you'll leave ruts, and I never wanted to have to mow or plow over someone's tire ruts. Chronically boggy areas in a commercial bee field can be graveled. We used smashed up concrete blocks because they were free.
Part of the reason a lot of people need 4wd is because they have it. The heavier front end makes the truck next to helpless in 2wd mode. My 2wd pickup goes places--without even spinning-- where my brother's-in-law other wise identical 4wd pickup needs 4wd just to move. Another reason for needing 4wd is poor tire choice. All season tires spin out on wet grass.
E locker would be my choice...only locked when you want it. Detroit truetrac is my 2nd choice since it never wears out.
I'd agree with this. Smooth on-road application and always working off-road as long as one tire is not in the air. You can also get a true-trac for the front diff too. I've heard of at least one farm truck on here running them front and rear.
I think the E-locker is an improvement over the limited slip that wears out, but I believe it only works under 15mph unless you cheat the system. Anyone who has ever been stuck in mud knows it very easy to get over that speed trying to clean the lugs.
That said, for play time in a Super Duty - 6.2L + 4.56s, ARB up front, TruTrac or Detroit in the rear, and 35" Nitto Trail Grapplers. Mash the pedal and pray you don't break a u-joint up front
Q: I was pre-reading the manual regarding the Electronic Locking Rear Differential...what was not clear to me is how to engage it with the Manual Shift On The Stop (Floor Lever)...it addressed ShiftOnTheFly and Two-Wheel Drive, but not 4WD with a manual transfer case. Did I miss it or did they not address it...can anybody please explain the process? Thank you.
