Aftermarket double din install
Metra double din adapter. Top and bottom is perfect. Small gaps on the sides with Pioneer AVH-X2800BS. I believe the kit I used was Metra 95-5818 — Kit. The trim plate needed some modification. Had to remove a bunch of plastic material from the dash.
FYI, I just bought a JVC double din unit, wiring harness adapter, and the Metra kit mentioned above. The factory double din unit is about an inch shorter than the aftermarket units. I'm gonna have to cut into the plastic above the radio to get the new one to slide in place. Not a big deal, but its more work.
gunnertom
11-02-2007 08:25 PM
BillyBob69
04-04-2007 12:46 PM
BIGRNU
09-09-2005 06:47 PM
jbrowning
06-18-2003 08:12 AM
