1968 Ford F250 Loose fan pulley
Loose fan pulley 2.avi
SOLVED PROBLEM - SEE LAST POSTING
1968 Ford F250
390
c6
Previously, I started a thread about a broken fan shroud and water pump replacement. I was about to fix all that, when I decided to make a small video to show the movement of the fan pulley that I mentioned in the previous thread. The movement of the fan/pulley in the video is the result of my lightly shaking the fan blade(s). A friend (not a mechanic) said it was a loose water pump, but now I'm not so sure. Until I fix the problem, I won't run the truck except to idle it --and then only briefly.
The four 1/2 inch bolts that connect the assembly to the pump are tight, as are the two belts. I didn't want to crack one of the bolts via over-tightening, so I thought I'd show the video and get some advice.
Any comments would be appreciated.
1968 Ford F250
390
c6
1968 Ford F250 390/C6.
The movement of the fan/pulley in the video is the result of my lightly shaking the fan blade.
If the shaft snaps, while running, you're going to have a lot more problems than replacing a water pump. Just my $.02
Murphys Law: Whatever can go wrong will go wrong!
Dan
recommended sealant?
Should the gaskets be sealed with what would be used on the bolt threads? I watched one video on Youtube about water pump replacement on a smaller block. I'm assuming most things would be the same for my truck: drain radiator; disconnect lower radiator hose from pump. His vehicle did not have a heater, so he switched a plug from the old pump to the new. (There was also a second set of hands assisting him at certain junctures; hopefully that was more for convenience than necessity.)
Sealant on gasket or no?
I am picking up the water pump today. I just watched a video that states that sealant is not necessary on a properly cleaned surface, that sealant was not used at the factory during the original installation. The video goes on to say that RTV sealant often causes problems. Should it be used or not?
