Heater Box New Core Dealer Add on AC 68 F100
I bought a new heater core thinking once the dealer add ac was removed it would be on the fire wall . After the add on ac was removed it was discovered that the heater core was moved into the dealer add on ac. Anyone know of a source for oem heater box? The add on A/C is cracked, rusted and beyond repair.
Here's one that should fit your 68. Not cheap.
1966-77 Ford Bronco Heater Box New Reproduction 3720
Here's a seal kit from Dennis Carpenter. If you get a used box you can clean it up and repaint it to look like new.
Air Heater Seal Kit | Dennis Carpenter Ford Restoration Parts
Core, metal back plate for box and rubber connector to vent hole in cab
This is the box body. I believe it's fiberglass
Vent flappers locations.
Flappers
This is what it looks like complete
When I took it apart I had to drill out the rivets. When I reassembled I used ss screws and nuts
Let me know if you have questions. I'll try to help.
I forgot. The fan and motor too
I bought a new heater core thinking once the dealer add ac was removed it would be on the fire wall.
After the add on ac was removed, it was discovered that the heater core was moved into the dealer add on ac.
THREE different types of A/C for 1968/72 F100/350. All are hang-on units, as their bezels bolt to the bottom of the dash.
1) Factory installed integral A/C is combined with the heater. The A/C controls are in the same panel as the heater controls.
The A/C expansion valve is located behind the glove box that has a shorter liner. There is another glove box located within the bezel.
C8TZ-18476-A .. Heater Core-Use with factory installed integral A/C / Obsolete
2) Deluxe dealer installed A/C is not combined with the heater.
The two A/C switches are located within the bezel that bolts under the entire underside of the dash.
3) Economy dealer installed A/C is not combined with the heater.
The two A/C switches are located within the bezel that bolts under the center of the dash.
C7TZ-18476-A .. Heater Core-Use with Heater & Deluxe & Economy dealer installed A/C / Obsolete
1967/72 F100/750 with heater & 1968/72 F100/350 with Deluxe & Economy dealer installed A/C
See post #9 for factory installed A/C pic.
btw: Where in OK do you live?
Interesting on your back road trip in Oklahoma. A military convoy antique military vehicles just passed by me headed for Santa Monica I believe. They are trekking Route 66.
I watched them pass through Edmond Ok about an hour ago. People were standing on the street corners watching them pass in the rain. They were given the green light all the way by local PD and OHP.
On the 12th, stopped at the U-Drop-Inn in Shamrock TX .. There were several Brits heading west on Route 66 riding rented Harley's.
Route 66 ends at Santa Monica Blvd. & Ocean Avenue (I'm a S/M native). I drove most of the OK portion. Already have driven Route 66 in AZ, CA & NM and a bit of it in IL
We don't smoke marijuana in Muskogee
We don't take our trips on LSD
We don't burn our draft cards down on Main Street
We like livin' right, and bein' free
We don't make a party out of lovin'
We like holdin' hands and pitchin' woo
We don't let our hair grow long and shaggy
Like the hippies out in San Francisco do
I'm proud to be an Okie from Muskogee,
A place where even squares can have a ball
We still wave Old Glory down at the courthouse,
And white lightnin's still the biggest thrill of all.
Leather boots are still in style for manly footwear
Beads and Roman sandals won't be seen
Football's still the roughest thing on campus
And the kids here still respect the college dean
A place where even squares can have a ball.
In Muskogee, Oklahoma, USA.
Thank you Merle.
TX: Vernon to Paducah to Matador to Shamrock then east to OK on 66 / KS: Coffeyville to Baxter Springs, then south on 66 to Quapaw / OK: Too many cities (including Muskogee)/towns to list.
